Caliper painting?
Discussion in 'The Garage' started by MTBLAZER89, Apr 28, 2003.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    I am getting ready to do my rear disk soon, and I want to paint my calipers. Anything special I need to mask or be careful of? I also saw some special paint for calipers and drums. Is this necessary? Thanks.
    -Brian
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I always use regular high-temp engine paint and it always works fine. Make sure that any trace of brake fluid is gone or the paint will not stick. </font>
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    VHT makes some good caliper paint, but you need an oven to bake it on. I think you'd need to remove the rubber parts from the caliper before that step. /forums/images/graemlins/eek.gif If you aren't going to bake 'em, then I'd just tape off the line fitting area, dust boot, and piston and start painting. /forums/images/graemlins/thumb.gif
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    I've alway's used just "clear" to cover stuff like that, D60 inner axle's, caliper's, u-joint's, any of that stuff that does'nt get really seen, but still need's to be coated to help out in the rust dept. /forums/images/graemlins/eek.gif
  5. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    POR-15 works pretty good. Just don't get it on any sliding or mating surfaces.
  6. 96chevysfa
    96chevysfa 1/2 ton status
    Jan 1, 2003
    230
    so cal
    i used por 15 and it started to peel on me, and these were refurbished, freshly sand blasted calipers that i treated with all the por 15 prep stuff.
  7. Jeremy_C
    Jeremy_C 1/2 ton status
    Mar 26, 2002
    1,381
    East TN
    I always used krylon flat black spray paint. Bout 97 cents a can. Always works for me. /forums/images/graemlins/thumb.gif
  8. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    VHT would work... if you dont have an oven its no biggie... i did my headers with VHT and I just left them in the sun on my driveway alllllll day long on a nice hot summer day. Worked great.
    j
