caliper pins, how hard do you torque them??
Discussion in 'The Garage' started by XHitman396, Sep 25, 2004.
  1. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    so i changed the pads, and if i remember correctly, i just torqued the caliper pins down as hard as i could with the 5 inches of leverage i had on the alan wrench, and one of the pins flew out as i was goin down the road, and the rest i think are loose. they're hard as hell to get in there, and is the little sleeve thing supposed to stick out of the caliper about 1/8 to 1/4 inch? should i use a cheater bar or something, any ideas on what i did wrong? thanks for the help...
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Try using the allen socket and a ratchet . I do mine all the time by greasing the smooth part of pin trying to avoid greasing the threads , centering the sleeves , slide in pins , then tighten until snug , then hitting the ratchet with my hand a few times to snug it more . They shouldn't come loose /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    thats what i do and they havent come loose yet. i also use the ratchet w/ allen socket
  4. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    I usually tap the allen wrench with a hammer a few times never had one come loose.
  5. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    With a torque wrench. About 80 ft/lbs, IIRC.
    You can get an inexpensive 1/2" drive torque wrench (10-150 ft/lbs range) for like $25 at Pep Boys, AutoZone, etc. I wouldn't build an engine with it, but it'll work fine for brakes, steering, lugnuts, etc.
