caliper question
Discussion in 'The Garage' started by makovai, Oct 28, 2006.
  1. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    As i'm doing my 3/4 ton conversion, i noticed somthing strange on the 8 lug D44. The front calipers had broke the casting right where the bolt go through the backing plate. I didn't think much of it at the time because i figured i'd use the calipers off my old 6 lug d44. The brakes calipers had the exact same casting number on both the 6 and 8 lug D44.
    So now i have the entire front finished and under the rig and i cant get the calipers on the backing plates. The holes are off by about an 1/8" and if i get them to go through it will probably break the casting just like the orignals that came with the axle. Whats the deal? Did the truck that had this 3/4 ton RG under it have the wrong calipers on it, or am i missing somthing?
    Help please
  2. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    Swap the calipers to the other side.
    When I did my 8 lug swap on my ten bolt I had the same issue, the caliper would not line up. Thanks to the advice from the guys here I got it fixed. All I did was swap the backing plates side to side. Then the calipers lined up perfectly.
    Hope this helps.
  3. makovai
    Jun 6, 2006
    854
    oregon city
    Thanks for the tip. I did manage to get them on, but i'm still concerned about the originals breaking and what will happen with these. Oh well it'll be next summer b4 i'm on the raod again, I'll just deal with it then if its an issue.
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Weld up the crack Jim
  5. 4X4HIGH
    Dec 14, 2001
    22,058
    69
    Pleasanton, CA.
    Did you use the caliper brackets from the 8 lug axle? The 6 lug and 8 lug caliper brackets are different by about a 1/4", 1/8" per side.
  6. makovai
    Jun 6, 2006
    854
    oregon city
    yes, i used the 8 lug backing plates with the 6 lug calipers. It should work and they did finally go on, but i have suspisions.
  7. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,991
    130
    Weld cast iron/steel? On the brake system :eek1:
  8. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Did you try to swap the backing plates side to side? I recall a previous post that mentioned that solved the same problem on their rig.
    Ira
  9. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Steel, yes.
    Iron, no.
    If you think about how steel is made, it pretty much all starts out as a casting. Whatever process' it goes thru after that don't change it's alloying, it's still the same stuff that came out of the crucible.
  10. goldwing2000
    goldwing2000 Guest
    The backing plates shouldn't be able to be switched from side to side. The plate has a little punched-out piece that fits into a notch on the steering knuckle. If you have them on the wrong side, then it shouldn't even seat correctly.
    That being said, I also had some problems lining up the caliper bolts but after I pushed the pistons back in, they fit fine.
    But then how do you bleed them? The bleeder screws will be on the bottom!
  11. hunterguy86
    Jan 10, 2005
    2,477
    San Marcos, Texas
    Glad you caught that. I was typing to fast for my own good. :doah:
    What I meant was, on my rig I had to swap the backing plates to the other side to get the caliper to line up.
