Caliper reinstall question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BowtieBlazer, Mar 31, 2002.
  1. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I got new calipers and can't remember from the old ones...
    What order does the copper washer on the brake line screw go in:
    copper washer / brakeline / bolt?
    brakeline / copper washer / bolt?
    I think its the first but not positive....
  2. muddysub
    Jun 23, 2001
    10,454
    493
    my garage, Henderson, NV
    copper washer/ brakeline/ bolt
    i just did mine like 3 or 4 months ago.
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    There is a copper washer on both sides of the brakeline.
    copper washer, brakeline, copper washer, then bolt.
    If you don't have both washers you will have a leak.
  4. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    yep two washers, one on either side or you'll be squirtin fluid...
    i just did this last saturday night both sides...
    2 washers...
  5. BowtieBlazer
    Jul 15, 2001
    2,462
    Funny you mention two brass washers. I just looked in the caliper accessory bag and there were two. The caliper I just removed only had one!!!
    Now anyone have any idea where these two little rubber o-rings go? Not the ones that the glide pin guides fit into....two much smaller ones. Wish these calipers had a small instruction guide with them...
  6. reddog64
    Nov 9, 2000
    3,325
    you should have 4 rubber "washers" they go inside the caliper bolt holes... the big in the big, little in the little... get it?
    look where the bolt goes... you'll see it...
    And dont for get the metal toob piece... like a 1/2 inch or 1 inch piece... you "may" need it...
