Caliper - Wheel Clearance?
Discussion in 'The Garage' started by Beast388, Oct 31, 2003.
  1. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I just wanted get everyone's input on what is a safe clearance to have between your calipers and wheels. I ground one caliper last night and it appears that I have about 0.030-0.050" of daylight.
    Is that enough?
    Thanks for the help! /forums/images/graemlins/thumb.gif
  2. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    That's about all I had. Actually... all I had was about the thickness of a piece of paper /forums/images/graemlins/ignore.gif
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I sprayed some black paint on the caliper/backing plate, mounted the wheel (torqued it down good with 4 lug nuts), folded a piece of 120grit sand paper twice (4 layers), held it in the wheel, and rotated the wheel. The areas that rubbed the sandpaper bad I filed down some more (I did most of my "grinding" with a file).
    It has rubbed a bit in the front...I think most of that was just mud trapped in between the wheel and caliper as well as differences in the wheels. I ground the using just one wheel...maybe you should pick the wheel with the worst clearace issuse and grind for that wheel.
  4. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    oughta be enough... keep in mind that someday when u get new rotors/pads etc you may need to grind more since the calipers will stick out more. When i set up my 60, i had new rotors/pads so its not a big deal... but for someone out there with need-to-be-replaced-soon rotors and just-a-lil clearance, it could be a problem.
    j
  5. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Yep, rotors and pads are brand spankin' new!! /forums/images/graemlins/thumb.gif
