calipers dont fit my 8 lug inner hubs??
Discussion in 'The Garage' started by down4thakrown, Jun 30, 2005.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    the calipers i have on my blazer wont work on the 3/4 ton inner hubs im tryin to put on. they have a little nipple that doesnt let them seat right. can i just grind the nipple off to make them seat right??
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    What little nipple are you talking about....pics would be good in this situation.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Are you using the correct caliper mounting brackets? When you go from 6 to 8 lug rotors, you also have to step up to the 3/4-ton brackets. The 1/2-ton brackets are a bit too small. :(
  4. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
  5. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    :D :D
  6. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    Yep there are 2 different calapers and backing plates for some reason. The parts store even has them under the same part # when you order them so watch out. However they are basicly the same and after you do a little grinding they bolt right up.
  7. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    sure are, fit perfect after some grinding :D
