Calipers for brakeconversion
Discussion in 'The Garage' started by keevy, Jan 7, 2005.
  1. keevy
    keevy Registered Member
    Aug 24, 2003
    36
    Belgium
    Can I use my 10 bolt front calipers for a break conversion for a rear 14bolt:blush:
  2. 85 BBC Blazer
    85 BBC Blazer Newbie
    Jan 7, 2005
    Avoca Ny
    Yes you can I think but you will have to use hoses for the 10 bolt calipers
  3. sweetk30
    Nov 1, 2004
    25,529
    527
    horseheads , ny 14845
    hose info
    i used the 10 bolt hoses and calipers for my kit and thay were 1/2 ton units . stoped on a dime with .09 change . go for it. also try to find a extra set of frt hose brakets and weld them to the axle to clip your hoses in to , or use flat steel and drill hole and clip in .good luck. p.s. dont forget adj prop valve.:cool1:
  4. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    I concur, my brakes didnt work worth a darn untill I put one in.
  5. keevy
    Aug 24, 2003
    36
    Belgium
  6. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    people use the caddy calipers because they have a e brake cable.
    so remember you wont have a parking brake, unless you get a line lock, or a drive line brake( but i think the caddies are cheaper)
  7. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    I just did the 10b... they bolted right up...
    Im using both a ds ebrake and a line loc..... caddies are ok but they need adjustment... arent bulletproof (I think) and are just about as expensive as a ds ebrake... but I had to make shafts anyways... you might not... then it might make sense to seek out the cheapest LOADED caddy calipers you can.
    cam
  8. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    Not trying to hijack here, but just a question about the adj. proportioning valve. Where did you install it. Did you just remove the factory one and put the adjustable one in it's place? What about the brake warning lamp? Can it be hooked back up somehow?
  9. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    You can either eliminate the OE Combo Valve and replace it with the Prop Valve (& union the front brake tubes), or you can install the prop valve DOWNstream of the OE combo valve in the rear brake tube.
    If you opt to eliminate the OE Combo valve you will loose the dash brake warning light.
  10. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    When I did my rear disk, I didn't do a thing....stock prop valve, stock 3/4ton m/c-booster and it stops on a dime....but I'm also driving a 7500lb burb :D
  11. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    read more here
    http://coloradok5.com/atrondiskbrakes.shtml
