Calipers Grinded but 15" wheel still doesnt fit, any ideas?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jimmy'sjimmy, May 8, 2003.
  1. jimmy'sjimmy
    jimmy'sjimmy 1/2 ton status
    Dec 22, 2001
    130
    Greenwood Village, CO
    Calipers Grinded but 15\" wheel still doesnt fit, any ideas?
    ok i have the new 14blt S/f all done, /forums/images/graemlins/cool.gif well except for the last part, putting on the wheels. we have grinded the calipers down a whole lot and my mechanic doesnt want to go any further. the wheels fit but when i turn corners they grind into the wheel pretty bad /forums/images/graemlins/confused.gif. any ideas?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: Calipers Grinded but 15\" wheel still doesnt fit, any ideas?
    Turning corners should have nothing to do with it. Tell your, "Mechanic" that he needs to grind until they fit. It's quite a long way until they fit, trust me. It sucks. I'd never do it for someone else just because of the liability. You might just have to do it yourself.
  3. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    App. how deep is the grind?
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    yeah like was said the distance betwen the caliper and the rim should be the same turning or not.
  5. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    ok i have the new 14blt S/f all done, well except for the last part, putting on the wheels. we have grinded the calipers.....
    Grinding calipers on a rear 14b sf? /forums/images/graemlins/eek.gif
    You don't have to do that on a 14b FF w/disc's..... /forums/images/graemlins/1zhelp.gif
  6. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Thats what I was thinking too I am running 15's on a 14bff no grinding at all. What disk setup are you running?
    -Brian
  7. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    the wheels fit but when i turn corners they grind into the wheel pretty bad . any ideas?
    More info. /forums/images/graemlins/confused.gif
  8. jimmy'sjimmy
    Dec 22, 2001
    130
    well i'm not sure what the axle came of of but it is 8lug and has some big a$$ braks on it. the 15in rim wouldnt fit until the caliper was ground down. its on there now but it still hits the wheel. its not that bad but it is putting little grooves on the wheel. he said he was trying to get some 1/4 in spacers or something like that. the wheels have 4&1/4 backspacing /forums/images/graemlins/crazy.gif, might explain why they arent fitting, i havent got a chance to go check it out cause ive been busy with finals, but ill be able to go tomorrow maybe i can get a little more info. he also said there was a little spacer that was on old style dodge motorhomes or sumthing that he was looking for at the junkyard.
  9. jimmy'sjimmy
    Dec 22, 2001
    130
    how far did u have to gind?
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I ground until they fit, period. Tons of guys have done it. My wheels are 4 1/8" backspacing and i had to grind for hours!! Yours are going to require even more than mine did.
  11. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    these are steel wheels, correct?
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Nothing else comes in 8 lug 15s but steel.
  13. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    So lets get this straight...Is this a rear axle with discs? Or a front axle? /forums/images/graemlins/confused.gif
  14. 83PJW
    83PJW 1/2 ton status
    Aug 18, 2002
    160
    leavenworth, ks
    wouldnt a newer one ton have discs? and if so wont they be bigger than a 3/4 ton? i dont know i did the disc brake conversion and all was good. yeah front or rear?
  15. wadinator
    wadinator 1/2 ton status
    Dec 18, 2001
    233
    NW Iowa
    /forums/images/graemlins/ears.gif
  16. jimmy'sjimmy
    Dec 22, 2001
    130
    its the rear, its off of a newer suburban 3/4ton i think. i took the truck home today and it grinds constantly, not just turning, so i guess i misunderstood him. anyway i dont have an e-brake now and the brakes suck /forums/images/graemlins/mad.gif. any ideas on what the next step i should take is. ill be trailering it home on monday, my dad got some 16in wagon wheels to drive it on the trailer. when at home i have a lot more resources. my dad is going to be pissed /forums/images/graemlins/angryfire.gif, so if anyone has any words of wisdom feel free to share.
  17. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    [/ QUOTE ] grind boy grind. Alright this makes sense now. A rear off a newer 3/4 ton Burban will be designed for 16" rims.
  18. TrailBlazinK5
    TrailBlazinK5 Registered Member
    Jan 13, 2003
    38
    Kansas
    So howd you finally end up on the grinding.. Im thinking of doing the same thing..getting a 76-78 3/4 Pickup and putting 15x8 wheels on it and wonder how much grinding ill be doing on the front calipers. And will the 15 inch wheels clear the drums in the back of the 12 bolt rear..
    bill
