Call me MR Bolts
Discussion in 'The Garage' started by az-k5, Dec 23, 2003.
  1. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Well I was out wheeling this weekend and sheard two G8 front shackle bolts (I had no spares). One on the passenger side upper and other on the driverside lower. I have 3/8 plate 1" longer shackles up front also. I now want 9/16" bolts with 3/4" .085 wall sleeves. Here is my question:
    Should I turn down a larger bushing of 1.500 od to a 1.125 od (this one has a .750 sleeve hole) or drill out the center of a my exsisting bushings from a .625" to .750" sleeve hole and just put the new sleeves in? (all bushings in reference are poly & for the upper and lower front shackle mount)
    I know ORD will be mentioned. I would love their bushing kit but want 9/16 so all spring bolts are the same. Does Watson offer a 9/16 bushing kit. I am aware of the 1/2" one.
    Thank you and any help along with runing jokes will be appreciated.
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    My blazer has 9/16 Spring bolts stock for the springs, but the upper shackle bolts are still 1/2". I would also be interested in running a 9/16" bolt for the upper shackle bolts too.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    damn man, you're rough on stuff!
  4. zcarczar
    Feb 10, 2002
    2,495
    He's not the only one with the problem. My buddy Chris that competed in TTC this year has a problem with breaking shackle bolts. Mysteriously he hasnt broken one in a few months, so I dont know.
    But Its front having crossover and with the wheels bound up in a tough to turn position the draglink acts as a torque arm and tries to move the axle away from the truck and breaks the heads off the shackle bolts.
    I think az-k5 doesnt have crossover so it sounds like he may have just killed bolts for some unknown reason.
  5. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    Dont know if what i did is "correct" but i took the sleeves out of my bushing on the spring and the upper shackle and just slid a 5/8" bolt in there. Made a huge differnce. Once again a i dont think what i did is necessarily right but it works great. Just a thought.
  6. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I'd drill it out. I think it would be easier (and cheaper) than trying to turn down a larger Bushing. Either way the outside area is the same thickness and your still ending at the same goal (3/4" sleeves).
    What are the shear points between 1/2 and 9/16? Was the one that broke greaseable?
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Last time I talked to him (a while ago) he said he was going to replace the bolts with larger ones and not run a sleeve. Maybe he got tired of breaking them and finally did it /forums/images/graemlins/confused.gif
  8. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Ding... ding...
    Matt... this is the way to go. Mike Arnold did this to his shackles at my house last night. 5/8" bolts in both ends of the shackle./forums/images/graemlins/thumb.gif
    ...and get long enough bolts so that the shackle's not riding on the threads. /forums/images/graemlins/deal.gif
    Marv
  9. white-rhyno
    Jan 27, 2002
    942
    Wow
    someone else likes my idea. I thought it worked great.
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    did GM always use spring bolts slid through sleeves from factory ?
  11. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    That 5/8 switch sounds neat but doesn't that squish the bushing cause you no longer have a sleeve? If I don't tighten the bolt a whole lot to avoid squishing the bushing won't the nut back off (even with a locknut)?
  12. white-rhyno
    Jan 27, 2002
    942
    use nylock nuts then tack weld them. Worked for me.
    i have brandbushing so they didnt squish out much.
    Brad
  13. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    The OD of the sleeve is 5/8", so I don't think the urethane could tell the difference in the sleeve and a 5/8" bolt. Only thing might be that you wear out bushings faster due to sliding/friction between the bolt and the bushing. Mike made sure to coat the bolts w/ lots of antisieze./forums/images/graemlins/deal.gif
    It's been my experience that ny-lock will back off of a lot of stuff. Metal lock nuts usually hold, and adding a jamb nut can really help (if done right).
    I'd try it and keep an eye on bushing wear. At least your bolt breaking days would be over...
    Marv
