Calling al 14ff disk conversion owners????????????
Discussion in 'The Garage' started by BamBamblazer, Mar 29, 2003.
  1. BamBamblazer
    BamBamblazer 1/2 ton status
    Jun 24, 2002
    486
    McCordsville, Indiana
    What calipers are you running? I dont want to get into a pissing match over which is better, the caddy or the truck calipers, i just wanna know what everyone used? Any dislikes on your choices or are you happy?????
    /forums/images/graemlins/k5.gif
  2. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    I'm running my old D44 front calipers, pads and rotors. Works just fine...I'm very impressed. I will eventually swap the Caddy calipers on so I can have an e-brake again though.
    Rene
  3. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    What brackets are you using? I'm just curious so I can follow the thread I'm doing the same thing and I dont want e-brake. /forums/images/graemlins/smirk.gif
    here are the brackets I have
  4. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    I'm using the A-tron brackets...
    If you can fog a mirror you can do this mod./forums/images/graemlins/tongue.gif
    Rene
  5. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
  6. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I've got a set for ford calipers on mine with e brakes...
  7. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I have Derbinator's brackets with my old D44 calipers, using the HAD driveline e-brake. WOrks real good for displacing air in the garage so far. /forums/images/graemlins/rolleyes.gif </font>
  8. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I am using the ecobit/misfit brackets, D44 calipers (with my old rubber soft lines). I also have a HAD e-brake which is attached to the 205 that is laying on the driveway rusting /forums/images/graemlins/rolleyes.gif
  9. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    IS THAT PIC UPSIDE DOWN?? WHY IS THE BLEEDER SCREW ON THE BOTTOM???? /forums/images/graemlins/confused.gif
  10. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    i am also using derbinators brachets.im actually doing the brake and 14 bolt swap today if it stops raining a little. /forums/images/graemlins/mad.gifno garage and still contimplating if i want to get wet today.anybody here figure out how to use the cadi calipers as an ebrake.i bought mine and it doesnt have an attaching arm to make the ebrake work.anybody got a picture of what the arm and return spring look like so i can maybe try and make one??
  11. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Im using Misfits brackets and D44 calipers.
  12. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I'm using my own brackets and the 3/4 ton chevy calipers. When I went to get the calipers the parts guy informed me that there were two different calipers one has a smaller piston then the other so I used the smaller one to help with any possible brake bias problems. Never heard anybody mention that on here before so I thought I would pass it along.
  13. thatK30guy
    Jan 12, 2001
    32,076
    55
    Whats the scoop on the bearing hubs? They look brand new. /forums/images/graemlins/eek.gif Did you buy some new hubs or what? If so, where and how much?
  14. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">They're machined down to fit in 6 lug wheels /forums/images/graemlins/cool.gif
  15. TONYP
    Aug 13, 2002
    2,116
    so cal
    Actually, those are the old ones that came with the 14FF when I got it. And because I'm keeping 6-lug rims, I had the outer hub dia. turned down the allow the 6-lug rim to fit on it. Then on the back side of the hub I set up and machined the die cast runner off and cleaned the rest up slightly will a CNC machine. they went from 24lbs. each to 17-1/2lbs each...so far I have shaved 75lbs. off the 14FF...and one day I might even get the damn thing under my truck...
    SUBFAN, [ QUOTE ]
    [/ QUOTE ] your right, but the axle is sitting on a bench...if you look you can see the spring preach on the bottom too, just the way I have it on the bench... /forums/images/graemlins/k5.gif
  16. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    ford what? and did you make the brackets or buy them?
  17. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    I've got the TSM bracket design that my friend made. One cool thing you can do with the TSM design is clock the caliper in different positions. I'm using stock 1/2 callipers, gutted the proportioning valve, installed a wilwood adj. proportioning valve, and using the chevette hoses. It stops like a sports car now!!!
