Calling all 1-TON First Gen's.....stock brake booster or upgrade?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Greg72, Sep 11, 2002.
  1. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Calling all 1-TON First Gen\'s.....stock brake booster or upgrade?
    This question is for the 1st Gen guys who have completed a 1-Ton axle swap.....
    I have recently completed this conversion, and didn't have any time before Moab to contemplate the swapping over of the 1-Ton Brake Booster. The brakes seem fine on the street, and if a slam on them I'm sure they will lock up.
    I do notice that the amount of pedal pressure needed to hold the truck at a stoplight is higher than other vehicles I've driven....it often "creeps" forward unless I make a conscious effort to hold the brake pedal down. In Moab, there were some STEEP downhills where I felt like I needed to stand on the brakes with both feet to keep my truck from moving..... /forums/images/icons/shocked.gif
    I'm wondering if this is a result of a 1/2-Ton booster trying to do the job of a 1-Ton...and there simply isn't enough hydraulic pressure to do the job? It's not a good feeling to "wonder" about your brakes....and I'd like know if any other 1st Gen guys have noticed this same thing, and/or have resolved it with the larger booster?
    It seems like a "no brainer" that if the factory designed the larger booster for the larger axles, it should also be used for 1-Ton "swaps" too.... /forums/images/icons/tongue.gif
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Re: Calling all 1-TON First Gen\'s.....stock brake booster or upgrade?
    Well Mr. 1Ton I have some input on this, if that's ok? Hey I have a 1Ton rated rear D60 and a beffy D44 so I have no Idea what tonage I am /forums/images/icons/crazy.gif /forums/images/icons/tongue.gif
    Anyway, the bosters come in two styles that I know of. Single diaphram and double. My father-in-law did the swap to the double on his 72stepside and that thing had some serious brakeing power, very cool!
    Someday I will goto the double.
    I would totaly do the swap if I were you. Heck even my whimpy lil 1/2-3/4ton K5 has troubles or could use more help breaking!
    Just DoIT!
    heheheh
    Later Bro
  3. BigMac
    BigMac 1/2 ton status
    May 27, 2002
    397
    Fremont, CA
    Have you presure bleed your brakes?
    my brakes are feeling spongy before the upgrade and I have new master and booster... my presure bleeder needs overhauled before I can try it.. just a thought...
  4. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Martin,
    The brakes feel strong (no sponginess) just like there's not ENOUGH of it!!
    That's what has been driving my thinking about a setup that can move MORE fluid into the larger calipers. Oh, and I have rear disks on the 14BFF which I know is yet another variable, but it should offer even better stopping power once I get it all figured out.
    If you can't tell, I'm looking for "cheap" stuff to play around with on my Blazer now that the paychecks have stopped again.... /forums/images/icons/frown.gif
  5. BigMac
    May 27, 2002
    397
    Fremont, CA
    maybe a junk yard 4 wheel disk master cylinder setup...
    I was eyeballing a newer chevy delivery truck that pulled up to work here. It had rear disks stock. It's had me thinking ever since about the bore diamiter of my current master cylinder. I know that in motorcycles we increase the bore diamiter of the master cylinder to give a more positive feel to the brakes.. it seems the same would apply here. I hope you get it worked out! Im going to have the same problems...
    what did you do for an e brake?
  6. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    e-brake is on the rear driveshaft, but the caliper for it is sitting on my workbench.....
    One of the "TO-DO" list items that didn't get done in time for Moab.
    /forums/images/icons/grin.gif
  7. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    OK Greg you're back and you have plenty of time now, so I want to see the E brake mounted by the party next week. /forums/images/icons/grin.gif
  8. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    I've been running 1 ton for awhile with the stock booster and stock prop. valve with disk brakes in the rear with no problems for almost a year now.
  9. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    greg
    i dont have the one ton yuou know but i am going to swap in a one ton on mine two. red aights are hard as hell to hold it still. someone i forgot who did it and saisd they had no probs. just my 2 cents
    nathan
  10. harry
    harry 1/2 ton status
    Feb 9, 2001
    106
    san diego, CA
    I have not driven mine yet (still being put together), but I decided to go to the 3/4 ton booster. My 69 balazer (D60, 14 FF, doubler, bla bla bla) now weights more than my freinds 70 K20. I decided to use the 3/4 ton on that reason alone.
  11. roostr3269
    roostr3269 1/2 ton status
    Jul 2, 2001
    305
    michigan
    Hey Greg, I also have the 1 ton setup but stayed with the half ton brake system. I have to stand on the brakes like u in order for it to stay put. I havent had it where I have been on a steep incline yet, but I am sure i wouldnt like it too much. Let us know what u decide cuz.... I'm in the same boat.
  12. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    Greg, I did the rear disc conversion and one ton MC and booster a while back and it makes a tremendous difference. My stock booster was a single diaphragm type and I swapped in a dual diaphragm booster and the difference was night and day. Now I can actually press the pedal down. Before I couldn't hardly move the pedal down. Go to the parts store and get a booster for a '72 C20 or K20 or C30. I had them compare PN and they're all the same. Plus they'll bolt right in with no modifications. Hope this helps.
    Will
  13. BigMac
    May 27, 2002
    397
    Fremont, CA
    is there a differance between the master cylinders on 1/2 and 3/4 tons? would it be worth while to replace both the master and booster?
    I whish I had known the differance in the boosters when I replaced mine a year or so ago...
  14. harry
    Feb 9, 2001
    106
    san diego, CA
    there is a difference on the master. I got a master and booster for a '71 K20 like 72THING did. The master cylinder part # is 1534 for A1-Cardone and 39075 for Reybestos. The Booster part # is 5471007 for A1-Cardone and I do not have the Reybestos #.
    If converting from 1/2 ton you will need to get new master to prop valve lines (inline tube). In 3/4 tons the front reservoir is for the rear brakes.
  15. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    greg
    one more tip i forgot. be careful on the doublefoot breaking. yesterday i was pumping up my breaks like i always do and my pushrod on the pedal snapped in 2. luckily i was in the parking lot at school and not trying to stop. i am assuming this is from how hard i have to press to stop and stay stopped. on an incline its nearly impossible.
    good luck
    nathan
  16. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    If you want less peddle effort you want a smaller master cylinder bore. If you do want to swap that out measure the bore of the 3/4 ton MC to see if it is larger or smaller.
    The double diaphram sounds cool. Wish I knew about it when I swapped my booster. Your other option is Hydro-Boost off of a newer desiel.
  17. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    triaged
    how do I find out about a hydro boost system and how to install one? How new of a diesel would it have to be?
    thanks
    nathan
  18. 72THING
    Nov 26, 2001
    501
    Ranburne, AL
    I've heard about getting a smaller bore MC for less pedal effort. I'm not sure if the 3/4 ton MC has a smaller bore or not, but I figured if I got the 3/4 ton booster then I might as well get the 3/4 ton MC. I thought about a hydraboost setup, but I wasn't sure if it would be a bolt-on affair due to the brackets on the firewall being different from those on later models. Has anybody else installed hydraboost on a 1st gen?
    Will
  19. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I think your best bet would be to search on the 73-91 forum for hydro boost info. I have seen a few systems but haven't seen what it would take to go into a 1st gen.
