Calling all 52" front spring Gurus, need bushing help.
Discussion in 'The Garage' started by zcarczar, Dec 3, 2003.
  1. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Calling all 52\" front spring Gurus, need bushing help.
    Ok in my attempt to install my 52" spring in the front im having some problems. First I was having problems with the mounts, now Im having bushing problems. The stock bushings will not work, they are too narrow. But I cannot find anybody with the correct bushing I need, and when I called Deaver Spring they had a bushing that might work, but I need to drive 2 hours to get there which means I have to take time off of work.
    So I need to find a bushing, Can anyone make bushings? Az-Kickin? I thought I heard of them making bushing for guys running Dodge D-60's up front.
    Another wierd thing problem I had is that my spring eye is 1.75", the guy at deaver said the stock spring should have had a 1.25" eye, but these are the stock rear springs off of my truck, I pulled them off of my truck and even took out the OEM bushings.
    I need some help. /forums/images/graemlins/1zhelp.gif
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Re: Calling all 52\" front spring Gurus, need bushing help.
    Just to get this thing straight:
    You want to use the rear 52" spring in the front right?
    Well the bushings should still be the same for the spring but to fit them in the front hanger you will need spacers or make a new hanger like I am making.
    On the shakle end you will have to make some shackles with the right shape and bolt hole size to match.
  3. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Jason, Yes I do make custom bushings for people includeing the front bushings for the rear ford spring in the AK-57. Make up a sketch of what you want and email it to me. Then we can talk about it on the phone but I't like to see what you want first.
  4. zcarczar
    Feb 10, 2002
    2,495
    WOOHOO, I'll makeup a sketch in a minute and send it to ya.
    Jason
  5. zcarczar
    Feb 10, 2002
    2,495
    Bill I sent you an email.
