Calling all electric guru's! *URGENT*
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CrazeeBush, Jul 5, 2001.
  1. CrazeeBush
    CrazeeBush 1/2 ton status
    Apr 17, 2000
    464
    Middle Tennessee
    Calling all electric guru\'s! *URGENT*
    Well, some of you may have read about my fire. Here's the damage.
    1 toasted distributor
    1 toasted carburator
    8 toasted plug wires
    and one helluva lot of wiring
    I'm in need of some kind of diagrams for wiring to the starter, alternator, and distributor. The main thick jumble of wiring that come through the firewall is in tact, so I should be able to cut off roasted parts and rebuild the engine compartment wiring. Anybody have a how to wire up your alternator,starter, and distributor for dummies guide? [​IMG] Anyway, all help is appreciated. Hopefully I'll have the truck running shortly. later
    -BuSH
    I'm a dislectic agnostic. I believe in a higher being, his name is DOG. [​IMG]
  2. Grim-Reaper
    7,385
    Atlanta
    Re: Calling all electric guru\'s! *URGENT*
    Library on Microfisch $.10 a copy. Year spicific.
    It's not my damn planet monkey boy!
    <A target="_blank" HREF=http://communities.msn.com/OffroadK5s>http://communities.msn.com/OffroadK5s</A>
    Grim-Reaper
  3. CrazeeBush
    Apr 17, 2000
    464
    Middle Tennessee
    hey hey, there's an idea. Was there much difference in the wiring for smog vs. no smog? just curious, I rid myself of the computer.
    -BuSH
  4. MRBIGBLOCK
    MRBIGBLOCK 1/2 ton status
    Jun 25, 2001
    472
    paragould arkansas
    a whole lot easyier to replace under hood harness with another one if yer not carefull ya might get another fire!!!!!!!!!!!!!!!!!!!! AND YES VIRGINNA BIG BLOCKS RULE!!!!!!!
  5. dyeager535
    26,982
    191
    Yes, save yourself the time and go find a complete underhood wiring harness and swap it. You've already got to replace the carb and distributor, so there won't be anything left in the way when you rewire it : )
    Make sure to get similar year, similar setup. (and not diesel!) IE 4 headlights on yours, you need a 4 headlight switch. Delay wipers on dash or in column? Those are the two things I can think of that are different between engine bay harness. As well, the engine harnesses are 3 seperate plugs on the firewall, so you may not have to replace the headlight one for example...
    Dorian
    My tech/links page: <A target="_blank" HREF=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</A>
    No anti-theft measures on your truck? No pity when its stolen
  6. CrazeeBush
    Apr 17, 2000
    464
    Middle Tennessee
    Alright now, I didn't burn the whole damn front off my truck. headlight ,horn, wipers is all there. Hell, the wiring for the starter is there, just singed a little bit. I just want a general idea of how stuff is supposed to be run. I think I'll be taking me a trip to the library.
    -BuSH
  7. dyeager535
    26,982
    191
    Well, in that case, it should be pretty easy. Once you get all the stuff over the wires out of the way (emissions hoses) you will see it is exceedingly simple.
    One wire for temp sender. One for oil pressure.
    One wire to dist.
    3 wires to the alternator. One to e-choke. 4(IIRC) to starter=one ignition, small, two fusible links, and the batt cable.
    These I'm not sure of, because I don't run them, but the AC has 2 wires likely, and the smog pump MIGHT have a wire or two to it, but I doubt it on a truck your vintage.
    Cruise control, I don't *think* it was on the engine in '83. Fender mounted still I think, so no wires on the engine.
    You also MIGHT have melted the blower 12 volt that goes across from the fuse panel, if it was routed across the back of the engine.
    Probably missed a couple, but I don't think thats bad from memory....
    Dorian
  8. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    well the underhood wiring is so simple and easy to do, its best to just replace it all. there could be places that are damaged that you didnt see and they could ground out and cause another fire. Just ask an elec shop if fixing only the visibly damaged wires is smarter than just replacing the whole underhood harness.
    Crawlin the rocks with my K5
    <A target="_blank" HREF=http://www.rockreadyk5.com>http://www.rockreadyk5.com</A>
  9. CrazeeBush
    Apr 17, 2000
    464
    Middle Tennessee
    alright, well where can I look about getting an underhood harness, and how much?
    -BuSH
  10. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Hey CrazeeBush....rather than rag on ya I thought emailing a schematic might be more helpful. If ya need any more email me and I'll scan em up. Good luck!
    Michael[​IMG]
    <A target="_blank" HREF=http://www.jmartin.net/parker/goose.htm>http://www.jmartin.net/parker/goose.htm</A>
