Calling all engine guru's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k5wantabe, Jul 1, 2002.
  1. k5wantabe
    k5wantabe Registered Member
    Sep 3, 2001
    30
    So. Cal. Lancaster
    Calling all engine guru\'s
    Getting ready for a two week camping trip. So even though everything was running ok I decided to give the Jimmy a tune up. I changed the plugs(ac delco cr 43st) the wires(msd helicore) and the cap and rotor(stock autozone replacements). After the truck runs rough around 35-45 mph. I checked the wires (all 2k-3k ohms) and made sure all had good conections. Also changed the o2 sensor during tuneup. So put the original back in after checks and test drove it. Seemed better but still some hesitation (seems kind of like missing) at 35-45. Could it be a vacume problem /forums/images/icons/confused.gif I noticed that the previouse owner had ac delco 44T plugs in. They are a little shorter after the threads. (the center electrode doesn't protrude as far out as the 43st's.) Could that make a difference? I was wondering what those of you with ac delco plugs are using? Going to drive it to work tomorrow (66 round trip) and see how it goes.
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Re: Calling all engine guru\'s
    I don't know the answer, but you could try posting at chevytalk.com in the Performance section.
    Just ask a question re: the difference between the two plugs and you ought to get enough info the help you figure it out.
    -- Mike
  3. Ovrtym
    Ovrtym Registered Member
    Dec 15, 2001
    21
    Virginia
    Just a thought, since you swapped out the wires/cap, double check the firing order to make sure the wires are going to the right cylinders.
  4. k5wantabe
    Sep 3, 2001
    30
    So. Cal. Lancaster
    Checked out the firing order and the wires last night. Both good.
  5. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Pull some plugs out and have a look. They should have some color like brown, tan, or grey. Black would mean too cold and the 44s wouls be better. I believe that gaps on TBI plugs are .040. Kinda funny because HEIs were .045. Hell, check all the plugs while your at it. Check the firing order using 18436572 with the even bank on the passenger and the odd on the drivers (I know you probably already know that, but can never be too sure).
    You could have bumped the distributor too. Look on the driver's side where the wires come out of the firewall. One tan wire with a black stripe breaks out of the harness. Unplug that and start the truck. Time the engine to 0 degrees. Turn it off and plug that wire back in.
