Calling All Speedi-Sleeve Gurus...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by aandpman, May 9, 2002.
  1. aandpman
    aandpman 1/2 ton status Premium Member
    Sep 6, 2001
    151
    7
    Austin, Texas
    I've looked all over the net at places like napaonline, etc. and no one has an actual part number listed for a speedi-sleeve to correspond to the hub seal area on a 14BFF. If anyone has DONE a speedi-sleeve job on their 14BFF, I would appreciate knowing the part number from the speedisleeve you used.
    Of course you all DO keep track of the part numbers of the parts you put on your trucks, don't you? /forums/images/icons/blush.gif
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    I did one of these on a 14FF once. I still have the box it came in. Unfortunately, I'm at work right now, so, for me to get the number will have to wait til lunch time. /forums/images/icons/wink.gif
  3. aandpman
    Sep 6, 2001
    151
    7
    Austin, Texas
    Thanks - I am patient and would truly appreciate that info.
    Can't wait to get the 14BFF in the truck. I just sent off the $$ to Derbinator for his Disc Brake brackets and I plan to go to Eldorado Calipers. It's getting so close I can SMELL it...../forums/images/icons/crazy.gif
  4. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    Hey,
    I did a writeup on a speedi sleeve install, but the host that it was on is no longer up.
    The NAPA part # is 'OIL SEAL P/N# 99282'
    I'll email you the write up with pics so you can check it out. Maybe I should send it over to Steve? would be a good article for the tech section .....
    Thomas.
  5. aandpman
    Sep 6, 2001
    151
    7
    Austin, Texas
    Thanks for the info.....
    That would be a great write-up for steve to put up in the tech section.....
  6. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
  7. aandpman
    Sep 6, 2001
    151
    7
    Austin, Texas
    Nice setup. If you don't mind my asking, who did you get your u-bolts from to mount your 14BFF?
  8. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I bought a spare the last time I did the job. The Carquest part number is 99282.
    Smitty
  9. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    Thanks! I had them made locally. There is a spring and brake shop here that will custom make them to what ever size you need.
