Calling EVERYONE running Edelbrocks..
Discussion in 'The Garage' started by 78Suburban, Feb 9, 2006.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    If you have an edelbrock in your chevy, I would LOVE to see what you are running for fuel line, and fuel fliter.
    thanks soo much :bow: :bow: ,
    James
  2. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    I dont have one anymore but when i did use one i used a 3/8 rubber fuel line with a clear plastic inline filter from o'reillys.
  3. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    That is how I installed my 600 a few days ago. cut the metal line where it bends in over the intake behind the alternator , put on the clear filter which came with all the fittings and hose to hook up to the carb. Cost like $2
  4. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    Sorry about the picture quality but I was shooting blind in the dark. This is the expensive way from Edelbrock or you just use a banjo style carb fitting with a 3/8 'th nipple and fuel line with a $3.00 fuel filter. One works as well as the other.:cool:
  5. Larry
    Larry 1/2 ton status Premium Member GMOTM Winner Author
    Jul 18, 2000
    1,096
    216
    A windy corner of a dirty street: Pueblo West, CO
    I took my time and bent up metal line fuel line to run the entire route with piece of 3/8 fuel hose to connect the carb. The filter is inline close to the fuel inlet. (not pictured) The whole mess is going a way for a Marine EFI system with in a few months anyway. Still in parts gathering mode for that project. If anybody has a lead on a Mercruiser L29 ECM I could sure use one.
  6. wetbackZO
    wetbackZO 1/2 ton status
    Jan 30, 2006
    113
    Las Cruces, NM
    3/8 rubber fuel hose and cheapo Fram clear filter...works.
  7. diesel4me
    Jul 24, 2003
    17,545
    936
    Massachussetts
    El-cheapo...
    I just cut the OEM metal line near the intake ,and added a metal inline gas filter,and used rubber fuel line to the fitting on the carb on my "performer" 1405 carb..had to use a spacer under the stock air cleaner to avoid contact with the rubber hose,my carb had a straight fitting that sticks out towards the passenger side,not a banjo fitting..I got the spacer off a chevy van's air cleaner,it jacks it up about 2"...:crazy:
  8. goldwing2000
    goldwing2000 Guest
    I bent up a stainless line from the pump and used a Fram G3 filter.
  9. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    WOW, I didn't even think of that. Where can I get a banjo fitting instead of my straight fitting?
    thanks,
    James
  10. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    I am running just a Edelbrock In-Line Fuel Filters. I will be upgrading my fuel line and carb when I cam my engine (Maby this summer if i have $$$$ left over from all the body work).
    Here is a pic
    http://yourautoplace.com/Project-k5/images/truck005.jpg
    (By the way this is a pic of my engine when it was in my old '85 not my '86)
    Adam
  11. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    :eek1: talk about CLEAN
  12. diesel4me
    Jul 24, 2003
    17,545
    936
    Massachussetts
    Banjo fitting
    I've seen the banjo fittings in Jegs,and Summit Racing catologs,and at Speed shops and some Autozone's and Pep Boys..they cost about 12 bucks...my cheapo friend made his own from an old front brake hose!..but I prefer not to jerry rig fuel system parts THAT crudely!..:eek1: ..but it DID work for him!..:crazy:
  13. 74poj
    74poj Registered Member
    Apr 12, 2005
    46
    Montana
    just installed a 650 avs today. ran the typical metal line up to the intake with rubber and inline filter the rest of the way. clean look, proven performance.
  14. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    this is how mine was. metal line -> rubber->filter->hose->carb.
  15. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Your basic type setup:
  16. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    I run a chrystler aplication guel filter with a return on it. I run an elecric pump and the return back to tank on the filter releives the extra. Seems to work great on my edelbrock q-jet
  17. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    if your runnin the performer series edelbrock,it might run lean in the cruise mode.I had to go one stage richer.Very easy though, the metering rods just pop right in takes every bit of 2 minutes.You will definitely know if its lean
  18. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    How will it act if it is lean?
    thanks,
    James
