Calling Mr. Watson--?? for U
Discussion in 'OffRoad Design' started by SCOOBYDANNN, Nov 8, 2005.
  1. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    what PSI can you comfortably run on your h2 rims and what size are they (the tires) im looking at running the same setup (if they are 40"s)
    thanks
    Dan
  2. PJTPW
    PJTPW 1/2 ton status
    Jan 14, 2003
    226
    Moab, Utah
    He's running Staun internal beadlocks, so he can go as low as he wants. He's running 42" IROKs.
    HTH
    Ryan
  3. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    doah!! nevermind
  4. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,069
    206
    Colorado
    James Cramer is running the H2s with no beadlocks and I think that he was down into the single digits and still had good bead retention with 42's.
    If not single digits he was real low in the double digits. I thought they worked well from the little bit I saw of his before he moved.
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    anyone got a link to the internal beadlocks?
  6. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    8-10 front, and 4-6 rear, and never heard a burp.
  7. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Makes me wonder why I have beadlocks. I guess I did go to 4psi or so on Hells Revenge at BB05 but it really felt too low.
    We sell the Stauns and I can give you some pointers on putting them in the H2 wheels.
  8. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,621
    610
    Hooper, Utah 84315
    You sell the Stauns
  9. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Yup, since we tried them and they work well, we might as well sell them.
  10. jac6695
    May 2, 2002
    1,860
    Christiansburg, VA
    So you don't need to worry like I do.
  11. kgblazerfive
    Dec 2, 2004
    10,621
    610
    Hooper, Utah 84315
    Makes sense to me
  12. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I think there are some traction advantages to the stauns too.
    1: Locking both beads to the wheel keeps the tire true to the wheel on both sides which has to help.
    2: the runflat effect from the liner extending up the sidewall a couple inches basically makes the sidewall shorter and gives less squirm/sidewall deflection at lower tire pressures. Basically it seems to deform in the direction of travel to give more contact patch and grab but still gives decent steering response and lateral support.
    The only drawback is lack of wheel protection.
