cam and intake question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Liberator, Dec 16, 2001.
  1. Liberator
    Liberator 1/2 ton status
    Jul 16, 2001
    276
    Communist California
    I found a GM Goodwrench 350 crate motor for my Blazer. The engine has about 80,000 miles on it. I spent a few hours today getting it ready to put in my truck but thought I'd do a few things before putting it in. I don't really want to use the stock intake/cam setup and was wondering if anyone knows the best combination for the motor. I was initially thinking going with a Performer intake and a Comp Cams Extreme 4x4 cam. Would this be a good combination? Does anyone else have any suggestions keeping the cost factor in mind?
    As far as I know, the engine is totally stock. I'll be running the stock Quadra Jet carb.
    Thanks in advance!
    Bo
    If it breaks, it wasn't good enough!
    http://coloradok5.com/gallery/liberator
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    OK, using the cam with the 206/214 duration and the edelbrock manifold will give you.... 232hp at 4,000 rpm and 321 lb/ft tq at 3,200 rpm. This is also using your stock manifold and 2.5" dual exhaust with no cats.
    At least this is what engine analyzer says.
    <a target="_blank" href=http://new.wavlist.com/movies/031/ag-blow.wav>"I ain't nobody, dork."</a>
  3. Liberator
    Jul 16, 2001
    276
    Wow! That's outstanding! Can you do another calculation! How about using the 218/226 duration, .462/.480 lift, 262 grind? I need to get that program you have!
    Bo
  4. Bigmeats
    Bigmeats 1/2 ton status
    Jul 29, 2000
    523
    Manhattan IL
    The comp cam is around 169.00 and the edelbrock Performer cam to match the intake is 109.00 Just checked the prices last week at a local shop, they are very close to summit prices
    Bigmeats.....Manhattan Il
    1975 Blazer
  5. Blazer_Boy
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Well, at 3,650 rpm, its pushing 314 lb/ft of tq. Its hits the 300s at 3,000 rpm and falls out at 4,300. At 4,250 rpm, its pushing 244 hp.
  6. Blazer_Boy
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Hmm, I'd go with the smaller cam. I have the 210/218 cam running my 400 (still have to tear the block apart) and its supposed to do 398hp and 461 lb/ft of tq. The biggest mistake when first doing cams is over camming. The numbers are just marginally higher, but the motor will idle rougher and have less vacuum. You'll need a bigger torque convertor because bigger cams make less power on take off, hence the higher stall speed which lets the engine build up power.
    (My 400 figures are a little inflated because on my example I have lower friction bearings, roller tip rockes, vortec heads ported for 5% more efficency, fancy manifolds, no accesories, and open exhaust....if your exact motor where on the dyno it would do 344 lb/ft at 3,400 and 255hp at 4,200, with the 206/214 cam. I forget to mention how leaving off accessories and mufflers helps to inflate figures. I'm sure companies do that when they advertise there crate motors. Go with the baby cam , more low end power and smoother operation.)
