Cam break in additive
Discussion in 'The Garage' started by BowtieRed, Sep 20, 2004.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    I don't have any, where can i buy it, i should be done with my truck tomorrow, but forgot to buy any- where do i get it and how much does it cost? I guess i shouldn't start the motor up without it. I can't wait to drive the truck! I want to make sure i don't screw anything up, i guess it's pretty inmportant.
    i know i need to keep it above 1500rpm for the first 30 minutes, but can i shut it off? and start it back up and then resume the break in?
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Cam break in additive? /forums/images/graemlins/dunno.gif
    Are you talking about the cam break-in lube that you slather all over the cam before installation? Obviously, that is not something you add after the cam is installed. /forums/images/graemlins/thinking.gif
  3. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    NO NO, of course i put that on, but in the directions it told me to use a cam break in additive in the oil.
  4. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Never heard of that. If you used the supplied assembly lube, things should be fine. Try and get the ignition close for quick start up, or you will wipe the cam clean and take a chance.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I wouldn't.
    EDIT:
    Unless it overheats or gets REAL hot.
  6. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I also have never heard of a cam break in lube. WIth my 406 I just greased up the cam with the supplied assembly lube and installed it. When we fired up the motor for the first time I ran it for about 10 mins at 1500-2000 RPM's and shut it off due to the temp climbing. Waited about 15 mins and fired it back up for another 5 mins, cool off, another 5 mins. I did my cam break in in stages due to how much heat a newly started engine produces, my old 3 core and stock fan couldn't quite keep up.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I've never sucuessfully broke a cam in without having it overheat, but I refuse to shut an engine down during a cam breakin unless the temperature exceeds 250 degrees.
  8. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    MMMM glowing headers and burning paint /forums/images/graemlins/waytogo.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/woot.gif
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Never heard of a additive for the break in, but I'm sure something like "Slick 50" would work.
  10. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Just say NO to SLICK SHIFTY....
  11. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Weird. Never heard of cam break in lube either. Never had one overheat while breaking in the cam either.
  12. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    When Ibought my crate 350 I got a little bottle of some engine break-in additive made by GM. It was in a little bottle, prolly a pint and it was blue. The instructions, for the motor or the additive, I don't remember, said to pour it in the lifter valley before bolting on the intake. After Iran the motor for 30 minutes, I drained the oil and added new oil, filter, and another bottle of the stuff for the next 500 miles. Then I changed it again for the next 2500 miles, after that I switched to synthetic. But this was for aa brand new motor, not just a cam.
  13. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    My Comp Cam came with said oil additive. Sounds like it doesn't make a crap whether you use it or not. Hope you enjoy the new HP /forums/images/graemlins/waytogo.gif
