cam choice and more ??
Discussion in 'The Garage' started by kerwinq, Mar 21, 2004.
  1. kerwinq
    kerwinq Registered Member
    Jan 25, 2004
    20
    Boise, Id
    I am going to be swapping engines in the 4X4 soon and what some opinions. I built a 350 with 10:1 and a mild RV cam in(not sure of the numbers) for a 2 wheel drive.
    This engine will be going in the 4X4 but I want to put a bigger cam in to give it more power. I would like to be able to hear the cam, (if I need to add a vaccuum canister that is fine) I have been looking at the extreme energy cam among others. What do you think would be good for a mainly street driven truck?
    I will be putting a 750 Carb on, is there a difference between the Carter and Edlebrock?
    What would be the best intake to go with?
    Thanks for the help, Kerwin
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
  3. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    I know someone (Beast388) with that very cam in his 388....It has a 'slight' lope at idle, and pulls very strong to about 4500 rpm's.
    I would guess with the smaller displacement of your 350, it would pull a bit more rpm and have a bit more sound at idle.
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I am using the cam that SUBFAN listed above in my 388. That cam was recommended by Comp Cams after I called and gave them all of the specs for my motor and application.
    I would recommend that you do the same. Being able to hear the cam isn't nearly as important as being able to mash the gas and launching......rather than stumbling. /forums/images/graemlins/waytogo.gif
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Call Comp cams at 1-800-999-0853 . Give them the specs on the motor, and what you plan to do with the vehicle, and they'll recomend a cam.
