Cam for 350 TBI
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Charly, Mar 29, 2002.
  1. Charly
    Charly Registered Member
    Mar 29, 2002
    28
    Portland, Maine
    hey,
    I'm thinking about putting in a 'different than stock' cam when I do the rebuild (which will be soon).
    It's an 89 350 TBI, non-roller, for now I'll keep the stock manifolds and heads. I obviously want torque at or near idle and up to about 4500 at least. I realize the stock cam would be near perfect, but was wondering if I could go one step up.
    I hear staying at 112* LSA is best, but I'm not sure if these 111" (one was recommended directly by Comp, but they said it was 112, there spec card says 111) cams will be Ok.
    Here are four that I am considering (all Comp) duration is at .050:
    PN 12-304-4, 201/206, 406/406, 111
    PN 12-388-4, 206/212, 425/440, 112
    PN 12-249-4, 206/212, 434/444, 112
    PN 12-231-2, 206/214, 432/453, 111
    Stock (I hear) is about:
    194/203, 395/415, unsure on LSA
    Comparing 12-388-4 vs. 12-249-4, for example, would more lift with same duration be better for the lower end?
    All the Comp cams are rated at 1000-5000 rpm, except for 12-304-4 which is idle to 4700.
    Concensus seems to be that the duration and lift of all of these will be fine with the stock chip, not sure about that LSA tough.
    Tranny will be NV4500 (w/ 6.34 first) with 4.88s and 38s for wheeling, 35s street/winter. This will be primarily a crawler, with some street duty
    Your thoughts?
    thanks,
    Charly
  2. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I am in the process of finishing my engine up, and I'm using PN 12-249-4, 206/212, 434/444, 112 so I can let you know how I like it.
  3. Charly
    Mar 29, 2002
    28
    Portland, Maine
    Thanks.
    When will you have that in and running?
    Stock chip?
  4. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    in about a week - week & a half...
  5. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    FYI these cam's are advanced 5 deg. by the manufacture when lining up the marks you are advanced...
  6. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I would also be interested in knowing how it works. I will be building an engine for my 89 either late this year or next spring providing this one lives that long. /forums/images/icons/smile.gif
  7. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    yea well this is the second TBI engine I've built in the last 6 months or so; I can let ya know which one I like the best etc.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have this cam: PN 12-231-2, 206/214, 432/453, 111
    It's great. Mine is in a 305 and it makes torque right off-idle to about 4500 or so RPM. It's a great cam, but,
    it won't work with TBI. You need a cam specifically designed for fuel injection to avoid problems. 111* LSA isn't going to work with a MAP sensor. Sorry man, take a look at a Compucam or something.
    Might work and be similar.
    Keep in mind, generally, lift=torque, duration=RPM.
  9. Charly
    Mar 29, 2002
    28
    Portland, Maine
    Actually, Comp stated that that 12-231-2 is a fuel injection specific grind, they suggested it to me....I wouldn't have even known about it except for them suggesting it.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That's a Comp Xtreme 4x4....it's the same cam I have. I would imagine it'd drive your MAP sensor nuts.
    I've been told keep fuel injected engines in the 112-114* LSA. I can't confirm nor deny that my cam won't work in a TBI engine, but I don't think I'd take any chances.
    It's a GREAT grind though, I'll tell you that. If you're not afraid to take it apart if it doesn't work out, I'd HIGHLY recommend it.
    And tell me how it works out too, I'd just like to know for future reference.
  11. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    I have a computer compat. cam in JMT that has a 110 lobe sep - but crane has done some funky stuff with it so the computers don't have a problem. still if it has lower then a 112 lob sep I'd call them again, and talk to somebody else to verify they aren't full of B.S.
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I agree. MAP sensors don't like overlap.
  13. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    no they don't, but the cam I'm talking about is a crane cam compu cam # 114122 - look it up sometime - 100% computer compatible with 110 lobes. I don't really like the cam though for my app cuz it runs real good, but it has a powerband that really kicks in at 2400 RPM - a little to high for me app (and the RPM range is 1500-4500).
  14. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Look up the Edelbrock TBI cam PN 3702. Thats what I've decided on for my 90 TBI 350 rebuild. Also call Crower and talk to their TECH's Hell, they'll grind one specifically for you for realitivly cheap!!
  15. Charly
    Mar 29, 2002
    28
    Portland, Maine
    I went with the 12-388-4
  16. Charly
    Mar 29, 2002
    28
    Portland, Maine
    Ok....I decided to go with the 12-388-4, I met someone with an almost exact same rebuild of the 350 and he uses this cam
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I think that's a mistake. The PN 12-249-4 would have most likely given you more torque. The specs, besides lift, are nearly identical.
  18. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    yea, and when I called comp cam's that is the cam they recommended. (talked with 2 different people)
