cam, heads, etc
Discussion in 'The Garage' started by adamforsythe, Sep 15, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    What would be the best cam and head combo to stick on a fresh 350?
    What power ranger would be best? (Idle to 5500RPM, 1500-6600, etc)
    It would be going into a K5 with a Th350 Np208 (soon to be NP205) 3.73 with 33" tires (Spring Summer fall time) 31" tires (Winter).
    I want to be able to to push the gas from a dead stop (NO BRAKE) and smoke the tires off. :bow:
    I will be adding a shift kit to the tranny also.
    I know the combo I want I just want to see what you guys would do.
    Adam
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    With those guidlines, the smallest Comp 4x4 grind, and a 2200 rpm stall converter. (For lighting the baloneys.)
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    Vortec heads and the biggest cam you can use with the stock valve springs (about .450", if I recall). Of course, you will need to buy a vortec specific intake and valve covers, buy you are setting up a fresh 350 so that shouldn't be a problem anyway.
  4. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    AFR's... if you don't have a grand laying around then get some darts for 800... if you can't afford that then go vortech.
    as for the cam... i'd like to try out one of those Zcams crane advertises as a bolt on 40 hp... supposedly it opens the valve quicker with the same amount of lift giving better off idle tq and mid range performance without losing top end.
    Or the tried and true 4x4 cam from comp cams. I'd look up the specs if it wasn't 2 A.M... :D
