Cam help
Discussion in 'The Garage' started by grindkings, Jan 4, 2005.
  1. grindkings
    grindkings 1/2 ton status
    Dec 24, 2004
    127
    Marshall, Missouri
    Is this an okay cam, or is it to extreme. I'm rebuilding a TBI 350. My rig is alsom my DD. Need a cam with some good power. but not outragous.VendorCompetition CamsProduct LineCompetition Cams Xtreme Energy 4x4 Cam and Lifter KitsCam StyleHydraulic flat tappetBasic Operating RPM Range1,000-5,200 RPM Intake Duration 050 inch Lift210Exhaust Duration 050 inch Lift218Advertised Intake Duration254Advertised Exhaust Duration262Intake Valve Lift with Factory Rocker Arm Ratio0.447Exhaust Valve Lift with Factory Rocker Arm Ratio0.462Lobe Separation (degrees)111Intake Valve Lash (in)0.000Exhaust Valve Lash (in)0.000
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    You will probabally need a custom chip with that cam to make it work right. The stock chip usually likes LS 112* or higher and not much more than 212* Duration @.050
    Check out the Comp Cam #XE294H its much mor TBI computer friendly. it will work fine with the stock chip
