Cam questions???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rick, Oct 26, 2002.
  1. Rick
    Rick Registered Member
    Oct 12, 2002
    16
    Bonifay, Fl.
    When you install a cam do you have to adjust the air and fuel intake on the carb, they tell me you have to adjust everything when you install a new cam, is this true
  2. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    sometimes, if the cam is a different size than the old one. and you have to do it because the engines air intake and exhaust, has been changed. the valves typicaly with a cam change will open longer and further than before. this requires more air and fuel. so re-jetting a carb is more often required than not.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  3. trouble1
    trouble1 1/2 ton status
    Sep 28, 2002
    346
    travelling, probably lost
    Yes....Something I'm still trying to get through....Mine was running extreamly lean, and I've over compensated at this point. I'm sure there is a easy way to take care of it, I'm just doing the old trial and error thing /forums/images/graemlins/tongue.gif
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Hell, if you're running rich, rig up the ol' spark plug in the tail pipe trick for some cool flame trowing !!!!
  5. trouble1
    Sep 28, 2002
    346
    That would give the Local PD something to do /forums/images/graemlins/laugh.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  6. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    OH yeah as if the local PD doesnt look at PI enough already. /forums/images/graemlins/deal.gif
    Theyre REALLY gonna like seeing the newest incarnation when it hits the road again late this week.
    And on the topic, yeah you will most likely need to readjust the carb when a new cam is installed. Everything changes. Even if your installing a new stock cam it will still be different (larger) than an old worn cam.
