Cam selection for 400
Discussion in 'The Garage' started by orangeGMC, Aug 3, 2005.
  1. orangeGMC
    orangeGMC 1/2 ton status
    Dec 26, 2004
    184
    Connecticut
    Does anybody have any recommendations on what cam I should run in my 400? I have found recommendations for 350s but is there anything different for the 400? I have also read about "small base circle", do I need to look for that? The truck never sees highway, just a little around town and trail. Spends alot of time in the mud. Are any manufacturers better than others?
  2. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    400 make good tourqe so get a good tourqe cam. and thay dont spin as fast as smaller motors so get one in the rmp range you will be most of the time:wink1: i like comp xtreme 4x4 cams
  3. orangeGMC
    Dec 26, 2004
    184
    Connecticut
    I found 2 comp xtreme 4x4 cams. Which would be better for low end torque?
    The red one or the blue one?
    Description
    Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 254/ 262, Lift .447/ .462, Chevy, Small Block, Kit
    Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 250/ 258, Lift .432/ .453, Chevy, Small Block, Kit
    Advertised Duration
    254 int./262 exh.
    250 int./258 exh.
    Advertised Exhaust Duration
    262
    258
    Advertised Intake Duration
    254
    250
    Assembly Lubricant Included
    Yes
    Yes
    Basic Operating RPM Range
    1,000-5,200 RPM
    600-4,600 RPM
  4. sweetk30
    Nov 1, 2004
    25,546
    542
    where do you run most of the time in power range? and what rpm do you lanch at most of the time? this will help you make a good choice:wink1:
  5. orangeGMC
    Dec 26, 2004
    184
    Connecticut
    In my truck right now I have a 305, so I have to stay up higher in the RPMs to turn the tires. The 400 is still on the engine stand so I don't know the RPMs it will be running.
  6. sweetk30
    Nov 1, 2004
    25,546
    542
    ah hell get #2 cam . the 400 will kick that 305 big time. :D
  7. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I went with the 262 grind, going with 4.56 gears and ported the crap outta the heads....
    What is the rest of the combination?
    Maybe mine will be in and running this weekend so I can give you the results.
    A friend of mine runs the 254 grind in his 388, and it is wicked strong til about 4500 rpm's. Sounds great, lots of throttle response amd torque....
