Cam shaft installation
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pomai, Dec 18, 2005.
  1. pomai
    pomai 1/2 ton status Premium Member
    Jan 26, 2002
    435
    3
    Oahu, Hawaii
    Does the A/C condensor deed to be removed in order to pull out the cam shaft. I figured it does but I thought I would just ask to make sure. Thanks Ed
  2. pomai
    Jan 26, 2002
    435
    3
    Oahu, Hawaii
    All I would like to know is if there is enough room for the cam to come out without removing the condensor? or does it need to be removed firts.
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Pretty sure you will need to remove it.
  4. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I've been able to work around the condensor on some vehicles by dropping the rear crossmember. This allows the front of the engine to tilt up for clearance. Just watch the distributer cap/firwall clearance :o . Handy if you don't want to open the A/C system.
  5. gn4u2c
    gn4u2c 1/2 ton status
    Oct 29, 2003
    287
    Pa 17329 zip
    I have found it faster and easier on your back to just pull the engine and swap it all over on a stand. These things are so easy to pull it just makes sence 1 hr - 1/2 depending on how rusty the exhaust is. Might as well do a timing chain, replace the valve springs/seals while your in there.
  6. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    The only problem with this for me: I end up rebuilding the entire engine once I have it out of the vehicle :crazy: .
  7. 84zz4ss
    84zz4ss 1/2 ton status Premium Member
    Dec 28, 2004
    1,342
    Pensacola FL
    When I did the cam swap in my 86 I did not evac the a/c. I just twisted it up out of the way. Held it with a bunjee or two. But the vertical support in the radiator support gets in the way. I cut it loose and welded it back when I was through.
  8. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    And I helped him do mine the exact same way.
