cam specs
Discussion in 'The Garage' started by adamforsythe, Apr 7, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Please post your camshaft specs. I want a idea on what you guys are running.
    Adam
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Factory GM LT4 camshaft(not the LT4 HOT cam):
    203/210 @ .050
    .476"/.480"
    115 LSA
    Roller
    idle - 4500 RPM camshaft
    Going in my TBI 383. Not built yet so no statement about it. Should be a torque monster with 10:1 compression, such little overlap, roller and the duration of course.
  3. Ryan B.
    Jul 18, 2001
    5,693
    CA
    what cam are you running in your engine that you posted the dyno specs on?
    In my tpi 350, i put in a "350 horse cam" hydraulic flat tappet.
    212/222 Duration @ .050 .435"/.460" lift 112 LSA.
    My 469 BBC for my street/strip camaro i'm going from a hydraulic roller 238/248 duration @ .050, .578"/.608" lift 108 LSA
    to a bigger solid roller cam..
    260/260 Duration @ .050 .587"/.587" lift 108 LSA
  4. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Here you go.
    http://www.compcams.com/Technical/Search/CamDetails.asp?PartNumber=08-409-8
    Adam
  5. akbound
    akbound 1/2 ton status
    Apr 20, 2004
    San Antonio
    This is what I am running in my 9:1 355. It is lopey at idle.
    Camshaft Specification Table
    Part Number 12-256-4
    Engine 1955-1998 Chevrolet
    262ci-400ci
    8cyl.
    Grind Number CS XE256H-12
    Description
    Intake Exhaust
    Valve Adjustment 0 0
    Gross Valve Lift 0.449 0.456
    Duration At 0.006 Tappet Lift 256 268
    Valve Timing At 0.006
    Open Close
    Intake 20 56
    Exhaust 70 18
    These Specs Are For The Cam Installed At 108 Intake CL
    Intake Exhaust
    Duration At 0.05 212 218
    Lobe Lift 0.299 0.304
    Lobe Separation 112
  6. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    here is what i run in my 355 (10:1)
    duration:
    .222/.222
    Lift:
    .447/.447
    Crane cams hydralic lifter replacement for the L-79 (327CID/350 hp) cam.
    same cam that came in the 350 hp 327's in the old corvettes but its hyd lifter and the grind is a little different.
    Real nice lopey muscle car idle.
    jegs part #270-WG-996K
  7. trailblazer86
    trailblazer86 1/2 ton status
    May 16, 2004
    112
    North Shore of Lake Ontario
    214*° 214° Wrong cam with 4:10 and 31's.
    The torque is too high up in the revs.
    I have 4:88's going in with 32" tires. Maybe 33's.
    This cam should work better now.
    If not I will have to install a stall converter.
    I am also running an over drive transmission.
    This may allow me to run the Edelbrock 204° 214° cam.
    I like the idea of big torque at low revs.
  8. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    230/236 duration at .050", 274/286 duration advertised, .490/.490" lift on a 110 degree lobe separation angle.
    350 cid engines enjoy 108 degree lsa's but most cam makers are grinding 110's
    unless you wanna fool with a circle track cam for maximum torque.
    Cylinder heads and compression ratio dictate cam choice but a dual-pattern cam is always preferred unless you're running AFR heads which have a great exhaust port and will over-scavenge the chamber unless a single-pattern cam is installed.
    do your research and make the right choice the first time.
    here is a link to my web page detailing the entire build of a 440hp SBC in my '79 short-bed 4x4
    http://mad-dog16.tripod.com/
    :crazy:
