cam timing question
Discussion in 'The Garage' started by big83chevy4x4, Jun 5, 2006.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    how would a engine run if the cam is one tooth off?
    with the base timing where it should be (tbi) it will idle just fine, but when you touch the gas it back fires threw the intake. if you advance it to 8-9* it runs like it should up to about half throttle, then just has nothing.
  2. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    Is it vacuum advance? Sounds like what my carbed motor was doing when I bought the truck. The advance canister was shot, along with the weight pivots in the dizzy being worn out. Dropped a new one and and it was running like a top.
  3. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    I think your symptoms could very well be a camshaft out of phase. Can you drive it ? Is it weak, and at about 2500 rpm's it hits a wall and just wont " go "?. With the air cleaner off, rev it by hand, does it seem like the air/fuel mix is blowing out? Like enough to lift the air cleaner base gasket up ?
    If you can answer yes to any of these questions, it's time to break out the degree wheel and dial indicator or pop that timing cover.
    Good luck,Cary
    EDIT- I like fab junkies thought also, I had a 350 running really weired one time, and it was the centrifugical weights in the dist. tangled up with each other:screwy: .
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    its a TBI so no weights or vacuum advance in the dizzy.
    yep
    quite a bit of power right off the bottom end for what it is (stock with RV cam) just the tach is way off (factory v6 converted the WRONG way:doah: ) but it seems just a bit lower than that, maybe at 2000 or somewhat but it does seem to fall on its face even with the timing way retarted. the hotter it is outside the better it is.
    no not really, deffinetly not enough to lift the air cleaner gasket.
    i just don't want to pull the front of the motor off to find that it isn't it. its gonna be almost impossible just to loosen the pan enough to get the timing cover back in.
  5. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,015
    848
    Pinckney, MI
    still cant figure out your cousins s10??
  6. theperfectgarage
    Oct 5, 2005
    988
    tucson arizona
    :thinking: I dont have any great ideas right now, and I agree, hate to pull the timeing cover if I dont need to.
  7. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    My timing chain was a tooth off (due to extremely poor markings on the crank gear), and it wouldn't rev past about 2500. Pulling the pan is a pain, but for me not so bad since it is a new one-piece gasket. Its a few hours to pull it down and put it back together, but will be worth it if you find it is off.
  8. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    nope, i had a half a though that maybe we were looking at the wrong thing with the TBI, thought it might be this.
    what way was yours off? not sure what would be retarted and advanced, but was it to the left or to the right? just curious.
    its not possible to pull the pan on this, you can bearly fit your hand between the pan and the front diff, damn IFS. we are gonna try to drop the front of the pan enough to get the timing cover in easily.
    the 1 piece pan was a very good idea on MY motor, paid for it self more than a few times but being reusable. we didn't put it on this motor, we were on a tight budget and couldn't find one cheap enough.
  9. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    The timing mark was to the right of where it was incorrectly sitting at...
    I guess that IFS thing is a pain in more ways than one.
