cam
Discussion in 'The Garage' started by okieone, Jan 7, 2003.
  1. okieone
    okieone Newbie
    Jan 7, 2003
    can somebody make sense of this information.
    and tell me what this cam is good for. this is the cam that is in my 350.
    Crane Camshaft Specification Card
    Part Number: 10008
    Grind Number: 282 H06
    Engine Ident: 1957-1987 CHEVROLET V-8 262 THRU 400 CU.IN.
    VALVE SETTING: INTAKE .000 EXHAUST .000 ----> HOT
    LIFT: INTAKE @CAM 3134 @VALVE 470 ROCKER ARM RATIO
    EXHAUST @CAM 3134 @VALVE 470 1.50
    ALL LIFTS ARE BASED ON ZERO LASH AND THEORETICAL ROCKER ARM RATIOS
    CAM TIMING OPENS CLOSES ADV DURATION
    @ --- INTAKE --- --- 282 °
    TAPPET LIFT EXHAUST --- --- 282 °
    SPRING REQUIREMENTS
    TRIPLE DUAL OUTER INNER
    PART NUMBER 99848
    LOADS:
    CLOSED 105 LBS @ 1.700 OR 1 45/64
    OPEN 273 LBS @ 1.260
    RECOMMENDED RPM
    RANGE WITH MATCHING COMPONENTS
    MINIMUM RPM 2500
    MAXIMUM RPM 5500
    VALVE FLOAT 6500
    CAM TIMING OPENS CLOSES MAX LIFT DURATION
    @ .050 INTAKE 12.0 BTDC 34.0 ABDC 101 °ATDC 226 °
    TAPPET LIFT EXHAUST 44.0 BBDC 2.0 ATDC 111 °BTDC 226 °
    REMARKS:
    Crane Cams continuously improves and upgrades its cam designs. In some cases this may mean that two Crane Cams with the same part number may actually be different grinds. You must check the GRIND NUMBER stamped on the front of the camshaft and check it against the Grind Number near the top of the Spec Card. For more information on the finest available camshafts, valve train components, and automotive ignition products, visit your local Crane dealer or call the Crane Cams tech line at (904) 258-6174 or FAX (904) 258-6167.
  2. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Sounds like a good cam. I think that cam has good power in the low to mid rpm's
  3. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Well, look at the advertised rpm range 2500-5500. Thats all mid and high range power and should probably be used with a 2500 stall converter. Really in a truck application 272 duration is plenty than you start getting out of the low end range.
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Thats a pretty good sized cam for a truck. You would want a little bit of a stall for its full potential.
  5. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    I can't seem to find where it says what the LSA (lobe separation angle) is. That is a huge factor in predicting a cams ability.
    John
