Camber adjustment - How much is there??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Pugsley, Jan 17, 2002.
  1. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I just noticed that my driver's front wheel is WAY out of whack from a camber standpoint - how much adjustment is there that I can get at home? - Or am I screwed and in need of yet another new axle?
    ......And knowing is half the battle
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    There isn't an adjustment. [​IMG] There are some shims that alignment shops can install behind the spindle to make small adjustments, but it sounds like you have a pretty serious problem if you can see that it's out of alignment. Check for worn balljoints, loose wheel bearings, loose spindle, etc. If you're lucky, that all it is. If you've been playing Dukes of Hazzard, then you might have bent the axle housing. [​IMG]
  3. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    My bet is you have a worn out upper ball joint. Do you know how to check a ball joint? As far as 'shimming', the upper ball joint sits in a off set hole inside of a threaded 'sleeve'. You spin the 'sleeve around to pull the top of the wheel in or push it out. I have heard of wedge shaped shims used between the backing plate and the spindle to get proper alignment. If I remember correctly if you change the upper joint you HAVE to presss out the lower to gain access to it- given that, replace both.
    Mudstud
    <a target="_blank" href=http://communities.msn.com/OffroadK5s6superliftand33s.msnw?albumlist=2>http://communities.msn.com/OffroadK5s6superliftand33s.msnw?albumlist=2</a>
    76K5 6" with 33s, sb400/350/203parttime/3.73-D44/GM12bolt
  4. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    You must be confussed in a Ford Dana 44 ?
    Check your FACT'S something smells fishy to me !
  5. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    No, it's my dana 44 front.
    Mudstud
  6. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Drag!!! Anyone got a left-hand output NP208??[​IMG] - Maybe just convert it to TTB and be done with it[​IMG]. The Balljoints are fairly recent, as is everything else - I guess GM just never designed these housings for Robby Gordon-esque blasts across Sonora. Anyone want a dead 10 bolt?
  7. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    MudStud: That adjustable sleeve that the upper balljoints goes into does NOT adjust camber. It merely sets the preload for the knuckle. The ONLY way to adjust camber is with those shims that go behind the spindle.
    Crawlin the rocks with my K5
    <a target="_blank" href=http://www.rockreadyk5.com>http://www.rockreadyk5.com</a>
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    TTB? Eeeeeeeeeewwwwwwwwww!
    "Time to replace my tires."
    "You just did that yesterday!!!"
    "I know, but I have Ford's greatest creation ever, TTB. I'm used to it."
    Tim
    '84 Chevy K10, lifted, loud, fast, and 3/4 ton axles<P ID="edit"><FONT class="small">Edited by 84_Chevy_K10 on 01/17/02 08:11 PM.</FONT></P>
  9. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    There is a replacement sleeve that is off set to use for adjustment. Well it was onec anyway.
    72 Blazer 400TPI NV4500 NP203/205, 6 bolt FF14
    01 Suburban 8100 2500 4X4
  10. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Sorry waxer, but there are offset adjuster sleeves that you can use to adjust caster or camber by 1 degree for sure and they may even make a 2 degree but not 100% on that one.
    I thought I was wrong once,
    but I was mistaken
  11. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    TTB rules in the desert - tough, simple, tons of travel, and the best feature - adjustable camber bushings[​IMG]!!! If only there were an improved knuckle available for the 10 bolt[​IMG]
  12. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Northstar makes alignment bushings up to I believe 1.5 degrees in increments of 1/4 degree. It replaces the upper ball joint preload sleeve with a sleeve with a bigger opening and another sleeve with an offset hole that slides into it. I think they are about 10 bucks a piece at my work.
    82 K5, 6.2L Diesel, sm465, np205, 14 bolt welded, 8 lug 10 bolt lock right, 410 gears, 35" Mud Kings
    SPEAK SOFTLY AND DRIVE A BIG TRUCK
  13. Waxer
    1,857
    Long Beach, CA.
    Dont be sorry...
    I'm speaking from an OEM perspective. I'm sure there are aftermarket parts out there that allow just about anything to happen. You go to Napa and ask for an upper balljoint and the sleeve that comes with it will not adjust camber.
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Not as simple as a straight axle, not as much ground clearance, not as much flex, and if tires would last, it'd still be lacking in all these other departments.
    Many of my friends have Ford farm trucks. Great trucks, crappy TTB.
    Tim
  15. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Actually TTB's are just as simple as a straight axle, only 2 housing sections instead of one, and a removeable 3rd member. Not as flexy, but 22" of travel without major modifications? That's good with me. Tires aren't a big problem with one that's well maintained, and in good alignment - I got 40K out of a set of mud terrains on my last F150 before the wear got too weird. Like everything else, it's all a matter of application, ya know?
  16. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    "Upper ball joint pre-load adjment sleeve". Should really be call a "Upper ball joint stud-seat height adjustment sleave".
    The sleave is "pre-loaded" to the stud/axle yoke, to set the distance between the upper and lower ball-joints stud seats.
    So, think of "pre-loading" is how the height is set.
    Caster/Camber sleaves are avalible, but are not G.M. parts.
    They are avalible up to 1.5 degrees total adj. For example :1.5 deg total caster or 1.5 deg total camber, or half/half like .75 deg caster and .75 deg camber. And everything binbetween.
    They are sold in 1/4 deg segmemts. Like .50 deg - .75 deg - 1.0 deg.
    Ford's Twin-Traction Beam suspension systems are a tool of the Devil....Sorry Pugs&lt;img src="http://coloradok5.com/forums/images/icons/smile.gif"&gt;
    <font color=white>.</font color=white>Eric
    <font color=white>.</font color=white>Twizted
    <P ID="edit"><FONT class="small">Edited by Twiztid on 01/22/02 06:02 PM.</FONT></P>
  17. Don 79 TA
    Don 79 TA Registered Member
    Dec 4, 2001
    12
    LI NY
    who is northstar and where can you find these shims?
    local parts store?
  18. BlueBlazer
    Feb 15, 2001
    1,940
    Northstar sells alignment tools and parts to alignment shops. You may not be able to buy from them direct, but you can go to your local alignment shop and ask for their parts or something comparable.
  19. Executioner
    Feb 22, 2000
    1,530
