camber??
Discussion in 'The Garage' started by Guss, Nov 11, 2005.
  1. Guss
    Guss Registered Member
    Feb 6, 2005
    78
    houston
    my driver fron looks to have camber when wheels are straight. is this possible on a 90 blazer whithout a bent axle. i dont have any vibration.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    are your wheel bearings or ball joints going bad?
  3. Guss
    Feb 6, 2005
    78
    houston
    just repacked the wheel bearings when i installed new rotors they seemd fine
    havnt realy checked the ball joints
  4. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    actually negative camber is when the tops of the tires tip in...and you get negaitve camber when you lower a vechile..go look at the ricers..positive camber is the top of the tires tipping out, and this happens when you lift a vechile..(non S.A.)
    and to counter act the crown in the road, you adjust the caster...
    toe and camber wear tires out, caster does not.
    but castor will cause the vechile to pull to one side or the other, and caster affects the rate at which your steering wheel returns back to center
    so to counter act the road crown you run more caster on the passenger side, so it pushes against the road crown, and the vechile goes straight.
    Allthough "technically" your not susposed to have your vechile go straight when you let go of the wheel..the road crown is there for A. water run off, and B. if you fall asleep, you will drive off to the side of the road instead of crossing over and hitting someone head on...
  5. garp0602
    garp0602 Newbie
    Feb 1, 2005
    3
    arkansas
    Thanks for the clarification sheoldeblaze. My bad on the castor, camber, toe post. I retracted it. Never want to get bad info out on the board.
  6. BIG*RED
    Mar 14, 2003
    1,094
    no problem, always glad to help someone out when i can :waytogo:
    Don't worry about retracting your post, its ok. we all make mistakes :D but thats why i like this place, even if your wrong, they don't "jump all over you" well for the most part they dont :haha:
