camo
Discussion in 'The Garage' started by ronnny, Feb 9, 2005.
  1. ronnny
    ronnny 1/2 ton status
    Nov 22, 2004
    838
    Newnan GA
    My son was asking me for his truck. How to do a camo paint job? I thought the blazer of the month is great but he wants more of some other type. I am not to much into painting or camo. He plans on the spray can way but any suggestion on how to do this and it come out ok for him? I know this is not the body work section but did not see many new post in there.
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    If you search under camo or something simular there is a few posts with links to military camo paint jobs, and some others.
  3. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I once thought about a mossy oak pattern. Using that stickon vinyle stuff like from bass pro or cabellas. I figured $800 to do the K5 which was cheaper than a paint job. I don't have a clue on how to paint camo.
  4. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
  6. sean'schevy
    sean'schevy 1/2 ton status
    Aug 5, 2004
    149
    New Egypt, NJ
    i spayed my camo colors with spary paint and then cleared it using a auto clear its held up well. the colors i used was rustoluem light olive / cheap 99 cent flat black and color works satin forest green. it took a while to find the right colors that i liked. If you dont want to use auto clear you can also use dulpi color 500 degree clear which you can find at any part store (its good stuff). Oh yea and watch out mixing different brand paints they might react to each other in a bad way. the paints i mentioned do not react to each other. but the stain forest green is hard to find at least by me. good luck and take you time with it.
  7. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Camo is easy. I use to do it back in the day to the military trucks when I worked with the 3rd shop. We used patterns for them to keep them all uniform in pattern. Just solid fluid lines with your cans to get your outline then fill in from there. Finding the right shades of paint can be a bit tedious. I could see if I have the CUCV pattern floatng around the house here. I was going that route but it is just too common so I decided to design the digital pattern on my truck. You tend to get alot of stares when driving a camo truck around town. Good luck.
  8. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    There is a blazer north of me that is painted in camo colors using a "trucker lady" or "silver naked lady" from a mudflap. Base coated in tan and they must have made a pattern to spray green, brown and black. Not really my thing, but it looks cool.
    There are several trucks around here that used leaves and palms as patterns. Theye all look like they used rattle can, but some of them look very well done.
  9. rerun93
    rerun93 Registered Member
    Dec 3, 2004
    98
    chico, ca
    i have been searching and searching and i cnat seem to find a dark green camo. stomper said walmart but all i saw there was blacks and browns and tan no green. anyone konw were i might be able to find this green?
  10. cbbr
    Jul 17, 2004
    14,681
    The Wal-mart close to me has it. You may just check another one.
  11. mojo-jojo
    mojo-jojo 1/2 ton status
    Sep 26, 2003
    101
    PGH PA
  12. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I just laid a base of olive green, and then held different plants from out behind my house up against the truck and went over the top of them with different colors. It's held up good for the last three years.
  13. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Check into a local surplus store. Around here we have a place called surplus city that sells everything from auto paint, tools, steel, and used stuff like hydraulic parts and electric motors. Anyway our surplus store carries rattle cans of the 3 flat camo paint colors. It's what I plan on doing to my trail rig and at $.99 a can you can't go wrong :grin:
  14. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Look in my gallery. I can e-mail the pattern i used if needed
  15. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Yeah the stuff I told you about was Rustoleum, exterior paint. I bought like 3 different kinds, picked the one I liked best and bought some more of it. I will post the UPC when I get to the house tonight.
  16. ronnny
    Nov 22, 2004
    838
    Newnan GA
    I really like readymix's paint but darrell was wanting more of some kind of mossy oak I think he said. It was mentioned about making lines in the paint before it dries to do some pattern? What kind of material is best to make a pattern out of? Poster board or? I guess also try not to go overboard with to many small colored spots.
  17. cbbr
    Jul 17, 2004
    14,681
    You can get a large roll of contact paper at Wal-Mart for about $7. Look where they have the stuff for drawers. Cut out the pattern, paint, move it and do your second color and so on. I did this with a friend many years ago. We used a piece of material as a pattern. Lay it on the contact paper, trace over it with a permanant marker, cut the contact paper and you sholud have a good pattern. Also works well for airbrushing flames.
  18. flatline
    flatline 1/2 ton status
    Sep 9, 2004
    167
    Cincinnati, Ohio (area)
    I bought all of my camo paint from autozone even though it's $3.99 per can it is a really awesome shade of Olive Drab ( nice and dark ) and it takes abuse too. I use roll/brush on Flat black on the trim and it comes together really nice. As for making patterns you could use just about anything for a pattern cardboard with a coathanger taped to it would be great and would hold up to numerous coats of paint. But the trick to camoflage is different patterns that blend together.
    I will post up picks of my finished work in a few minutes.
    Okay, here are the pictures, I started with a flat black base coat on the entire vehicle, to give it a deeper shade.
    Now after 16 cans of OLIVE DRAB rattle cans and a little touch up with Flat Black here is the finished product.
  19. big_black_blazer
    big_black_blazer 1/2 ton status
    Dec 19, 2004
    114
    Western Kentucky
    it's been a while, but the last time i was on www.therangerstation.com they had a few pages on how to paint camo. i know it's a (cough!) ford site, but it's still good info.
