Camshaft compatability with TBI...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89GMCSuburban, Dec 24, 2002.
  1. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I just replaced the engine in my truck (200 miles on the new stock engine), and with it I put it a new Elgin performance cam. Anyone have Desktop Dyno?? Here are the specs:
    Cam Lift INT=.280 EXH=.295
    Valve Lift INT=.420 EXH=.443
    Lobe Centers INT=107 EXH=117
    SAE Duration INT=271 EXH=280
    .050 Duration INT=204 EXH=214
    SAE Timing BTC=27 ABC=71 BBC=76 ATC=32
    .050 Timing BTC=-5 ABC=29 BBC=44 ATC=-10
    I put the cam in but don't notice any real increase in power except for a loped idle. What's up with that??? This cam is VERY similar to the one installed in a certain 270hp replacement motor for the truck based on a GM Goodwrench stock replacement engine for my TBI.
  2. K5on38s
    K5on38s Registered Member
    Dec 11, 2002
    90
    Buffalo, NY
    Hmmm, What's the power range in the cam....... maybe it'll need a stall converter to "pep" it up a bit /forums/images/graemlins/deal.gif
  3. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    It supposed to be 1500-6000 RPM range..I cruise at 2,200 RPM but don't notice a whole lot of difference.
  4. dyeager535
    26,982
    191
    Compare those lobe centers to factory GM stuff. I believe all the injection cams (stock, or aftermarket "computer compatible) are up in the 112*-114* range.
    Has a lot to do with vacuum as I recall, what does yours pull at idle?
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If that cam lopes, something is wrong. I have a bigger cam than that in my K10 (not much bigger, but bigger) and it doesn't lope at all.
  6. YtseJam
    YtseJam 1/2 ton status
    May 19, 2002
    147
    CT USA
    The Lift on the factory cam is .383 INT. .403 EXH
    So it's not all that much bigger. Your power increase won't be that much greater. You may notice a nicer soiunding idle, andd a noisy PCV valve with the TBI.
  7. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    If you really want all you can get out of the cam, you will need to reprogram the chip.
    www.thirdgen.org
    Have fun!
  8. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    I can check the vacuum for you, I have a guage.
    This cam profile is .003 lift off of a cam that supposedly bumps up the engine to 270 hp, maybe my timing is off...
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Don't just focus on lift numbers. Two cams could be very different and have the same lift specs.
  10. dyeager535
    26,982
    191
    Probably wouldn't hurt to check, from the sound of it, that cam shouldn't "lope" if everything else is right.
