camshaft degrees
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by timebomb1602, May 12, 2001.
  1. timebomb1602
    timebomb1602 1/2 ton status
    Mar 30, 2001
    138
    hudsonville, MI
    Hey I was just playing with an engine program I have and was wondering what I should degree the cam at on a 350?
    It seems like a 5dg RETARD gives good power, but would it work?
    <font color=red>1991 GMC Jimmy 350tbi 3.42</font color=red>[​IMG]
  2. xtreme_wlr
    xtreme_wlr 1/2 ton status
    Mar 22, 2001
    103
    San Diego, CA
    Been awhile but I think it is 4deg retard for more top end power and 4 deg adv for better low rpm grunt. Generally, best bet is straight up. Most aftermarket double roller timing sets are made so you can do 0, 4+ or 4- at the crank sproket.
    '78 Chevy 1 ton Stepside RockCrawler
    468 BB, SM465, NP205
    D60 front, GM 14Bolt rear w/ Detroit
    <A target="_blank" HREF=http://65.11.18.114>http://65.11.18.114</A>
  3. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    I just lined the marks up on the two spoikets. Worked well for me. I guess if I was building a fast car and not a truck i would take the time to degree the cam, but on a truck, its not that big of a deal.
    Sparky
    When all else fails... Check the blinker fluid.
    78 K-5
  4. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    TB, Just install it straight up. It isn't worth playing around with on a daily driver IMO. This is really something for the guys who shellout for the 2 piece timing covers and have access to a dyno and/or drag stip. The changes generally are realtively small on stock and only mildly modified stuff.
    1987 Chevy K5 Blazer- 350 TBI
  5. WARP1
    WARP1 Registered Member
    Apr 8, 2000
    63
    Omaha, Nebraska
    If you have the tools go ahead and degree it. You could be off a tooth when you line up the marks. Either way I'd just try and install it straight up.
