Camshaft Qs
Discussion in 'The Garage' started by Chevy305, Jun 5, 2006.
  1. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Solid lifters vs Hydrolic lifters:
    I have heard that Solid gives you more power, but hydrolic is more user friendly. What do you guys think about solid lifter cams? Also can you put one into a block that is meant for a hydrolic cam?
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    All I know is that solid needs to be adjusted a lot, but I see more and more people using them on the street.
  3. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    You can use either type, the solids often with grinds that make more power. Kind of a pain to adjust, I only use them on pure performance engines. Theres a place for them, it depends on the application and the individual.
  4. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    basically if the engine sees 6500rpm or greater you'd be well advised to run solid lifters. nothing wrong with hydraulic lifters below that.
  5. kwissman
    kwissman 1/2 ton status
    Jan 14, 2006
    118
    Austin, TX
    Solid lifter cams will typically produce a little more torque. This is due to the fact that the lifter will not compress and you can get the valve open faster. The current designs for street solid lifter cams are quite good and will typically need adjusting once a year depening on the mileage driven. Once the cam is broken in you will need to adjust it a few times initially. Check out the voodoo line or the lunati solids that were designed by Harold Brookshire. He is the previous owner and cam designer of Ultradyne. He has good designs that are easy on the valves and make good power.
