Camshaft selection opinions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by thatK30guy, Feb 4, 2007.
  1. thatK30guy
    Jan 12, 2001
    32,076
    55
    Don't know whats going on in the garage but no one seems to be able answer this simple question.
    Truck specs are:
    '85 K30, 454, 400, 205, 60, 14, 4.10, 4" front and rear springs, 35" tires.
    454 is mildly built with a 260 Comp Cam with .475" lift. This cam is a dog. Rest of engine has an Edelbrock intake with an Edelbrock Q-Jet, Hedman headers, dual Sonic Turbos.
    400 is all B&M built. Shifts good and crisp. Stock converter.
    I'm looking at Lunati cams. I've selected one that I want to get more power and speed from. I don't want to change converters. I need someone who has the program-thingie to let me know what I can expect out of this cam I pick here: 292 degree advance duration, .544" lift, 2000-5500 RPM range.
    How will this cam perform on this truck? I'm not looking for a tow hauler or fuel economy. I'm looking for POWER but not too outrageous. This cam part number from JEGS is 638-00024LK.
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    This cam is too much for the torque convertor you have.
    If you don't want to change convertors, you need something a little milder.
    However if you use this cam your engine will be a dog on take off then it will wake up at higher RPM's
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    That cam is also too much for the stock heads. That baby is made for the drag racer set. Like IceMan said, it'll bog off the line, then set ya back in the seat when it finally gets up to its optimum operating RPM. But with stock heads you'll still be leaving at least 50-100 HP on the table. :( They just won't flow enough to take full advantage of the extra breathing that cam is capable of.
    When you say that the current cam "is a dog", what are the symptoms? No bottom end torque or does it run out of power too early up top?
  4. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Lunati Voodoo Cams is where the power it at! :bow: :bow:
  5. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    So the big question is, which of those VooDoo cams would be "best" for mine?
  7. MetalMelter
    MetalMelter 1/2 ton status
    Jan 20, 2006
    401
    EARTH/COLORADO
