camshafts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KASS, Mar 19, 2001.
  1. KASS
    KASS Registered Member
    Mar 6, 2000
    7
    Oregon
    With this '88 Blazer I have a stock 350. I would like to do a top end rebuild because of smoke on start up and oil consumption. With all the "towing" camshafts availiable what would be recommended? And would the TBI or any other component have to be altered to accept a different cam?
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I think that you have the hydrolic roller cam. Replacement cams for these are around $240 without lifters. Comp Cams and Crane Cams make stuff designed for your engine. Give both a call and ask which one to use.
    '71 Blazer CST with alot of rust
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    An '88 won't have a factory roller cam. (Unless it's a 6.2L diesel). The 350's used a flat tappet cam. [​IMG]
  4. Andreas
    Andreas 1/2 ton status
    188
    Sweden
    If you got smoke on startup, a top end rebuild won´t solve it I´m afraid [​IMG]. Smoke on startup usually indicates worn valvestem seals. If it´s smoking all the time you need to hone (and possibly bore) the cylinders and get new rings.
    /Andreas
    406cui of pure sh*t[​IMG]
    <A target="_blank" HREF=http://hem.passagen.se/znus/>http://hem.passagen.se/znus/</A>
  5. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I thought they changed in '87 (when they went to a 1-piece rear main seal). What year did they change?
  6. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    What ever kind of cam you have make sure that its one designed for a motor with TBI.
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    I think roller cams came in on the Vortec's
    <font color=green>Stupid tourist at Mammoth Cave, Kentucky: "How many miles of unexplored passages are there?"</font color=green>
  8. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I just replace my intake and cam on my '90 Jimmy. The cam is a flat tappet cam. I used the Edlebrock intake and cam combo. The cam is a very mild and does a good job of low end torque and really improved the power throught the entire range. The cam and intake are designed to work on a TBI engine without changing the chip.
    Derf00
    http://www.derf00.coloradok5.com
  9. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    My '87 TBI 305 has a roller cam, according to Crane Cams. That's why a new cam for my truck is so much more than normal.
    [​IMG] Semper Maintenance!
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    They put roller cams in the 'vette engine starting in '87. But the trucks kept the flat tappet cams. At least that's what the GM factory service manual shows. The 4.3 V6 got a roller, but the 350 didn't. Even the factory service manual for my '94 Suburban says it has a flat tappet cam. [​IMG]
  11. Emmettology 101
    May 9, 2000
    8,126
    FL
    Smoke at start up is usually caused by bad valve seals. These seal only cost about $10 and can be changed with some tools and air pressure.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
  12. Brians 60s
    Brians 60s 1/2 ton status
    Jun 12, 2000
    1,115
    Bend, Oregon
    Kass, HHmmm isn't that the name of the first member of the mamas and the papas that died in 1974?
    "IF YOU'VE NEVER BEEN STUCK.....YOU'VE NEVER BEEN WHEELIN"!!!
