can 52" springs be used without altering axle location
Discussion in 'The Garage' started by GMC500, Mar 27, 2007.
  1. GMC500
    GMC500 1/2 ton status
    Aug 19, 2005
    203
    Safwa
    hello
    can I use stock 52" rear springs in the front without altering axle location ? and without upgrading steering setup?
    truck is driven in sand and mud and alot on the pavement
    no rocks here
    I live in Saudi Arabia
    and I want to lift my truck 4 inches of total lift ( springs in the front + shackle flip in the rear )
    but shipping a set of lift springs will cost me too much ( USA to Saudi Arabia )
    or
    is there any other alternatives
    thanks
  2. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    Waaayyullll.... I spose you COULD use 52"s with the stock axle location by moving the rear hangers back ~2-2.5" and moving the front hangers forward the same.
    If you kept the axle location the same, you could stick with the same steering setup.
    Just seems ... like it would be a lot of work. Maybe see if you can get your existing springs re-arched locally?
    -- A
  3. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    re arching is a waist of time and on stock 47" tapered leaf fronts it is not safe or recomended.
    i think he is right tho on the moving of the hangers out both ends a bit and it would work for ya. if you were a member then you could search and there is tons of info on 52 " spring swaps with lots of pics also.
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    if you are going to take the spring out of the rear of ur truck, what are you going to use in the rear for the shackle flip??
  5. GMC500
    Aug 19, 2005
    203
    Safwa
    I have access to a free set of stock 52"
  6. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    Sand mud and pavement equals no real need for the benefits 52's provide.Take your stock front springs, use the main leaf with bushings, and mix and match other leaves to get the lift you want.
  7. GMC500
    Aug 19, 2005
    203
    Safwa
    is it OK to use this method to get 4" of front lift ?
    I mean wouldn't that alter the pinion angel too much
    thanks
  8. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    It might but even lift springs from aftermarket companies come with a tapered shim to make this correction. There are vendors onhere that can get you the correct degree shim once you figure out what the angle is
  9. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    Yes, You can. If you just move the front spring hanger directly under the Body Mount Bracket(instead of in front of it) it will not alter wheelbase, and the shackle angle will be right where you want it.
    Yes, it would be wise to add bumpstops, and maybe even a limiting strap on the drivers side to prevent bind in the steering and to keep the tires from hitting the fender or wheelwell. Its ideal to go to crossover steering, but you dont have too.
  10. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    I was thinking that would work but never seen it done, do you have any pics? Friend has a k5 we are building and crossover isn't in the budget for him yet.
  11. Blazr77400
    Aug 31, 2001
    652
    Ogden, UTAH
    A couple of guys on here did it. I tried looking for the pics, but no luck.
    Everybody on here says there is no point on doing a 52 inch swap and leaving the axle in the stock location, or there is no way you can do it without crossover.
    It'll work, just not as good as using crossover and moving the axle forward for tire clearance.
    I think a set of stock 52" in front, and a 4" shackle flip will make for an awesome riding Blazer.
