Can 6-lug rotors be used on 14FF disk swap?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bubba Ray Boudreaux, Dec 1, 2002.
  1. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> How exactly would you get them to attach to the 8 lug hubs? The wheel studs press through the bolt holes in the rotor and into the hub on the disk swap.</font color>
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">It has been done. Both sides of the hub have to be machined to 4.175" and new stud holes have to be drilled
  4. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Cool, thanks for the info.
  5. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    If you do it, show lotsa pics! I am still fighting with my inner self about going with the 14FF only cause of the 8 lug wheels. It took me forever to find my rims I have now, and to switch to plain jane ones is just heartbreaking!
    Mike
  6. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
  7. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Well, this came up in conversation last night with someone, they were trying to sell me on the benefits of this swap. If I could do it with minimal heartache and get everything I want, 6 lug, 15" wheels, then I would consider it.
  8. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
  9. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    And for everyone else out there, no, I am not considering a swap, just doing a little research to further my knowledge so I can assist fellow wheelers in their quest. I forever will stay loyal to 10 bolts. /forums/images/graemlins/thumb.gif
  10. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
  11. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Link's not working.
  12. TONYP
    Aug 13, 2002
    2,116
    so cal
  13. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I have some questions if I may
    The first is did it add to the width at all ?
    Next is what are you running for the front ?
    The reason I ask is I'm looking at going with a 14b and would like to keep my wheels it would look funny with two type's of wheel's. Lastly you said it cost you 150 to do the swap did that include the disk brake deal as well?
    Eric
  14. Thumper
    1,582
    Alberta Canada
    Is that a kit you are doing or something you did yourself? I am talking about the 8 to 6 lug conversion.
    Mike
  15. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    It would not change the width because the drum/rotor goes on the inside of the wheel flange
    You would just run a 1/2-ton front...or a D60 converted to 6-lug but I don't know why you would do that.
  16. blazer72
    Apr 13, 2000
    939
    KCMO
    I run a D60 that came out of a 1ton duelly Cheaper to buy the hubs from dyna track than the one from GM stayed with the 15" wheels and Tire I had
  17. TONYP
    Aug 13, 2002
    2,116
    so cal
    The 6 to 8 lug ring is something I made, I'm making a setup for the rear disk brakes right now....
  18. TONYP
    Aug 13, 2002
    2,116
    so cal
    I'm doing a disk change over on a 14FF. I'm adding 1"inch to the hub on each side, I could go only 1/2"inch if needed. The 14FF is not as wide as the Dana44 so going out a little on each side I hope won't be a problem, I don't want my tires to hit the outside of the fenders when stuffed up inside. You have a 1st gen. so how did it turn out? /forums/images/graemlins/ears.gif
  19. Highlander
    Nov 25, 2000
    1,204
    Lakewood Colo
    Thanks for the info to bad about the width. As for the front I was thinking the same.
    We'll see what will happen with my rearend problems as to what I'll do.
    Eric
