can a 2nd gen flip be used on a 1st gen....
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 55Willy, Jul 31, 2006.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    if i were to bolt in a 3/4 ton rear out of a 73 to a 91 into a 1st gen k5 instead of hacking the spring perches off could I use the 2nd gen style spring mounts to move the spring mounting width to match?
    thanks
  2. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Not likely......
    You may have made the rear part of the spring/hanger work, but the hanger width on the front side of the rear leafspring will still be wrong.
    Does that makes sense?
  3. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    what about getting a 2nd gen rear spring front hanger and changing out both mounts.???
  4. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    it'll work. just need rear spring front hangers. (2wd for stock settings) but i'm gonna get 4wd ones for more lift.
    the rear flip is lower then a 1st gen style so there more lift there and I won't have to run such a long shackle.
    WOOHOO!!
  5. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Why not just build an "offset" rear shackle???
  6. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    I already have 2 sets of extended shackles that I bought. and both styles of ORD flips.
