Can a 2WD NV4500 be converted to 4WD?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by arveetek, Apr 18, 2002.
  1. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    I notice that these trannies have removable tailshaft housings. Is that all that is required? I have read that I must change the output shaft to 32 spline. What is involved in this? And will an NV4500 bolt up to an NP208?
    Casey
  2. Charly
    Charly Registered Member
    Mar 29, 2002
    28
    Portland, Maine
    Yes, you will need to change the mainshaft out and change the tailhousing.
  3. arveetek
    Mar 1, 2002
    722
    I've overhauled engines, swapped TH350's to 700's, converted gasser trucks to diesels, but I've never changed a mainshaft or even been inside a manual gearbox at all. Is it hard to do? What's involved?
    Thanks!
  4. Charly
    Mar 29, 2002
    28
    Portland, Maine
    If you've overhauled an engine, you can rebuild a manual tranny.
    Quite frankly, it's simple.....
    ....the "hardest" part is the fact that you need a press (and then it's ridiculously simple).
    For special tools, all you need is a decent set of retaining ring pliers ("eaton" style pliers are the correct ones....available from McMaster-Carr for $14), a dial indicator to measure end play and possibly a spanner socket for the mainshaft nut....
    I just rebuilt and swapped the shafts on a 93 commercial 2wd NV4500, this one had no mainshaft nut, not sure about the other 2wd versions, but the 4wd mainshaft does have one.
    Seriously, it's nothing to be afraid ofat all....I don't have access to the link right now, but there is an online review of the GM technician's reference manual that is still available, cost $19, it is invaluable, it does not have a teardown, but it has clear pics and driagrams of the assembly, torque specs, and powerflow. It's worth it's weight in gold when you are reassembling the tranny.
    I'll get the link soon, but you can also look on the Pirate board (Chevy section) and under favorite links (it's at the top) I have it listed there.
    Charly
  5. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Was it an expensive swap? What else was needed, beside the mainshaft?
  6. Charly
    Mar 29, 2002
    28
    Portland, Maine
    Here's the link to the manual review (with purchase info):
    http://www.off-road.com/jeep/reviews/jlnv4500.htm
    If nothing else, I suggest purchasing this reference manual, even if you personally don't swap the mainshaft.
    Other than the mainshaft, you will need the mainshaft nut, damper and tailhousing (w/seal). The rest will be bearings etc......if needed. Rebuild kits for NV4500 (w/synchro rings) end up costing in the neighborhood of $3-500.
    The mainshaft I was looking for (different application) was below $200, and I happened to find a tailhousing used for $100. The spanner wrench cost $50, but I was able to find a dealer that actually lended it to me for the day (I was surprised too).
    Contact Novak Conversions directly for a price on a mainshaft. You can tell Eric that I sent you.
    http://www.novak-adapt.com/
    Charly
