can a body lift be put on a diesel?
Discussion in '1982-Present GM Diesel' started by bigjblazer, Sep 21, 2002.
  1. bigjblazer
    bigjblazer Registered Member
    Apr 9, 2002
    89
    Atlanta, GA
    I have an 84 k-5 that i already put a body lift on, and a 75 k-10 which is getting one next week. My friend has an 83 jimmy with the 6.2 diesel. Can she put a body lift on it, or will it require extensive modifications?
  2. calcide
    calcide 1/2 ton status
    Dec 21, 2001
    283
    K5s are not little jeeps.
  3. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    W.O.W sounds like my kind of woman a fulsize K-5 and a deiesel /forums/images/icons/grin.gif
  4. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Damn you beat me to it! /forums/images/icons/laugh.gif
  5. bigjblazer
    Apr 9, 2002
    89
    Atlanta, GA
    i meant, bow to the almighty k-5, you little jeeps. like talkin to the jeeps, cause i always had to pull em out. Yeah, the girl is fine too. And she loves her rig. It's awesome. well, can anyone tell me if the bod lift will work?
  6. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    I dont see why it wouldnt.
  7. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Yes you can put a body lift on a diesel as well as a gas powered K5.
    The only difference is with the trany. The engine will not be affected either way but the transmission will need attention. If it's a manual you will need to enlarge the opening on the tunnel and if it's an auto you will need to extend the shift linkage other than that you will need to check for any wiring or fuel hoses that might need some loosening to extend the amount of the lift.
    If you already had a lift on your K5 you have been through it before and you should be able to do it on the diesel.
    IceMan
