Can a cross over be done w/
Discussion in 'OffRoad Design' started by i_4x4, Oct 28, 2001.
  1. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    Can cross over steering be done w/ only 2" Suspension lift? I figure i'll have to trim some on the cross member. All cross overs i've seen have been 4" or more. This is also for a D 44. Any suggestions would be appreciated.
    Later Ed
    Get use to the view.
    Because, if your not the LEAD DOG the view never changes.
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    hoserr has crossover with none or very little lift ...
    WHATS WRONG WITH A 305 ?
    81 K10 GOODYEAR 35" MTRS
    TH350 NP 208
    O R D's axles
    NO BREAKAGE :)
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I think you can do it, but like you say, you will have some clearance issue to work on. a set of taller bumpstops, or some spacers may be useful. My custom leaves were build to compress into the factory "full bump" location and it worked with the crossover so it's definitely possible. Stuff to watch for is the pitman arm to spring clearance and the draglink to frame clearance on the right side. And of course the crossmember.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
