can a flange mount be replaced with a u-joint mount on a front driveshaft
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Dec 7, 2002.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    Im looking to buy a diveshaft but its the flat flange type mount and I need the u-joint type of mount. can this be switched out? I alreay have a driveshaft that has a CV on it with the u joint mount but its too short to use and the splines are worn out. I would assume that I could just switch the CV's right out. Or is there something im not thinking about /forums/images/graemlins/confused.gif
  2. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    anyone?
  3. RATAH
    RATAH 1/2 ton status
    Aug 10, 2002
    576
    Franklin,Ohio
    TTT not to rob your post
    but i also need the same thing
    i have the front drive shaft from a 700r4 flange mount
    and need 1 for a th350 u-joint 26 inches long
    can these be made from the flange mounted shafts?
  4. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Here it goes! I had this problem last week! I just recently put a 205 behind a 700 R4 and went from a flange from a 208 to a 205 with a front u-joint output... The lengthened drivshaft I bought had a flat flange attachment and I wanted to switch the two out... The problem was that the front output on the 205 was a 10 spline output and there was never a 10 spline flat flange.... I than had to buy a Ford 205 and switch the 32 spline front out for the 10 spline I had, The Ford has a U-joint yoke on it as well, but you can eather buy a 32 spline flange from Jesse at High Angle Driveline, OR go get a front flange off of a 208(which I had) and slide it onto the front!!!!! Works great! /forums/images/graemlins/grin.gif
  5. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    no, you cannot change a flange style driveshaft to a yoke style. the cv sections are different lengths and the cv ball is set up differently. youre going to have to find a driveshaft from the early to late 70's.
  6. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    not what i wanted to hear but ok
