can a flexplate warp from excessive heat?
Discussion in 'The Garage' started by LKJR, Nov 7, 2002.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    auto tranny, title says it all
  2. BARRAZA
    BARRAZA 1/2 ton status
    Oct 17, 2001
    259
    USA
    Are you talking heat like from a fire or just normal engine heat? Normal hot engine, shouldn't cause warpage. In a fire, maybe, but that would be the least of your problems.
  3. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    talked to my mechanic today he said sounds like it may be a cracked flexplate..supposed to stop by tommorrow evening to look at it, excessive heat as in motor getting really really hot to the point of stumbling
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    never seen one warp from heat. Have seen them crack alot.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    If the flexplate is cracked, Summit sells SFI approved flexplates for around $55. They are MUCH stronger than a stock flexplate. /forums/images/graemlins/cool.gif
  6. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    cracked a couple from a blow torque converter never heat warped
  7. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    that didn't make any sense....blown torque convertor? god I hope that's not it, I'm too poor to start replacing more stuff
  8. hammer
    Aug 29, 2001
    449
    Binghamton N.Y.
    blew up a torque converter only way we knew was each new flexplate broke in less than 5 min.
    Yes it got expencive repacing flexplates everyday
  9. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    how did it act? in other words was there not any sign of the torque converter acting funny?
  10. hammer
    Aug 29, 2001
    449
    Binghamton N.Y.
    the flex plate vibrated from the stator being broke in the torque converter. Took the torque converter off for the hell of it and it went klunk and pieces fell out.
