can a gm tbi be used on the holley projection manifold???
Discussion in 'The Garage' started by COCHEV, Mar 18, 2003.
  1. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    i want a manifold for tbi that will bolt to pre 87 heads and have egr provision. the holley one looks like a winner but it says its only for their projection. here is the link:
    holley
  2. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    Never done it myself, but according to everything i've read, yes. They also offer one with an 87-up intake bolt pattern. Both have 2" throttle bores and are quite a bit cheaper than the edelbrock manifold.
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I think you can do it if you buy the adapter from carb to TBI.
  4. bowtiepower00
    May 11, 2000
    924
    AZ
    The manifold(s) in question are TBI manifolds (no adapter needed). They are called projection manifolds because they aren't CARB approved for a stock TBI application.
  5. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    why aren't they approved if they have egr?
