Can a winch be mounted vertically?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 8_YOUR_H2, Jan 17, 2002.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I have seen them mounted horizontally to a plate on the lower part of a bumper, and There is a winch bumper on ebay that has winch mounted to the front or vertical part of the bumper. This would be ideal for me. Can all winches be mounted this way?
    Brent
  2. Glock Girl
    Glock Girl Registered Member
    Jan 15, 2002
    54
    NY
    There use to be a winch called the "sidewinder" same principle. Its biggest downfall was that gravity had a tendicy to pull the cable down to the bottom of the spool all the time bunching it up. I would think you would have a simmilar problem. If the winch had a oil bath gear box it probably would not lubricate well either.
    Shelby
    88 K5
  3. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Do you mean like this: []
    or like this == ?
    The way most winches mount is with four bolts through the bottom in a rectangular pattern. This type of winch could be mounted just about however you want. Other winches have bolts that go through the bumper into the front of the winch (Warn 8274, M15000) so these have to go behind the bumper.
  4. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    It would still be mounted like this
    But instead of being bolted to the bottom plate it would be mounted to the front of the bumper
    brent
  5. RedDwarf
    May 9, 2001
    816
    Yeah, that's what I thought you meant. Yeah, you can do it. Any of the planetary winches under 10K lbs will be able to do this, and they use grease for lube anyways.
    What will you do to protect the winch from trail obstacles or collision?
  6. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    my winch cant, i have the spur gear driven warn 8274, and all the oil would leak out the free spool lever hole
    beligerence doesn't justify intelligence.
    <font color=blue>wheelers hate posers.</font color=blue>
    <font color=red>79k15/400/700r4/205/38.5</font color=red>
  7. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    you mis understand the question ryan. Your winch ALREADY mounts like that, thats how it has to mount. against the vertical front of the bumper. (or in your case the winchbox.)
    -matt
    <font color=purple> "Stuff's only good for 2 things, degreasing engines and killing brain cells"</font color=purple>
    <a target="_blank" href=http://www.geocities.com/shaggyk5>www.geocities.com/shaggyk5</a>
