Can anyone answer this puzzling question....
Discussion in 'Other Rides' started by Donna, Aug 27, 2002.
  1. Donna
    Donna 1/2 ton status
    Feb 20, 2001
    2,377
    Gettysburg,Pa
    I'm jhoping some one can answer this. I'm posting it here because the problem is driving me crazy and I'm sure that Wayne hasn't thought to ask. /forums/images/icons/crazy.gif Anyway....the "idiot" light in my dash for my emergency brake kleeps coming on. WHY??? Wayne has checked it and can't find anything. The ebrake works too. It doesn't do it all the time. Just if the vehicle is going up hill or around curves. WHY???? It's driving me crazy. Anyone have any clues?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    The switch may actually be going bad...there is a spring inside the switch that returns it to the normal position and so when your going uphills or around corners it is thinking that the ebrake is on. Only reason I say this is because I had this happen to me right after I bought my burb. Hope this helps.
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Yeah, Same thing happened to me. I unhooked the switch.
  4. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    try adding brake fluid. The e-brake light will come on if you are low on brake fluid. The e-brake switch and the low brake fluid switch use the same light.
    Dan
  5. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Could be a number of things.
    There is a switch on the foot pedal for the parking brake. If the foot pedal does not come all the way up, or moves when going up hills, cornering, etc., it may cause the light to come on. The switch could also be faulty or bent.
    The light will also come on if you are low on brake fluid in either the front or rear (or both), and it may come on before you even feel you are low with the pedal. My buddy had to replace his proportioning valve with a new one because the sensor went bad. The sensor for low fluid (actually senses a pressure differential between front and rear) is located in the proportioning valve up on the front crossmember. He could not find just the sensor/switch (I have been told you can get them, but never tried myself) and he just ended up ordering a new prop valve from www.inlinetube.com. Hope this helps.
  6. Donna
    Feb 20, 2001
    2,377
    Gettysburg,Pa
    The brake fluid has all ready been checked....Like I said, the light comes on only when turning really hard turns or up hills. I'll have wayne check the switch thing though. thanks guy's.
