Can anyone decode HEI part numbers?
Discussion in 'The Garage' started by BigBen, Jun 27, 2006.
  1. BigBen
    BigBen 1/2 ton status Premium Member
    Nov 14, 2002
    1,194
    Grand Haven, MI
    I'm going to send my HEI in to get rebuilt and figured I'd write down the numbers to see if MSD sends my actual housing, etc. back..... :)
    As I was writing them down, I started to wonder where this Distributor came from. The PO swapped it into my '74 long before I bought it.
    Stamped on the main housing (largest diameter) are stamped numbers
    1112880 5014
    Down where the housing sits in the manifold is stamped
    J2
    The advance weight mounting plate has 126 on it.
    The weights themselves had 130 stamped on them.
    About the only thing I can track down is that it looks like 1112880 means a distributor out of a '75 4bbl engine.....
    Anybody know anything more about these?:confused:
    Thanks,
    -Ben
  2. diesel4me
    Jul 24, 2003
    17,567
    942
    Massachussetts
    Maybe..
    I have an old Ac-Delco tune up spec book that lists distributors by the numbers,but all it tells you is if its from a car or truck,and what size motor and carb--(and you already know that!)...
    The only other stuff it tells is the amount of vacuum advance it has at a given rpm,at a given number of inches of vacuum..thats about it..if you need to know, I can look it up and post back later tonight with the details--I'd do it now,but the book is in my garage,and I'm not there at the moment!...:crazy:
  3. BigBen
    Nov 14, 2002
    1,194
    Grand Haven, MI
    It would be cool to know where it came from, but you're right that the specs won't make a difference once I change all the guts.
    I just found out that the Tech Rep at MSD and I had a misunderstainding... they only rebuild MSD distributors, they don't work on GM ones.
    Long story short, I'm looking for parts for this one so I can rebuild it myself. (more fun that way anyway). The pins on the advance plate are my biggest problem right now They're worn to the point that I'm afraid bushings won't last.
    -Ben
  4. diesel4me
    Jul 24, 2003
    17,567
    942
    Massachussetts
    junkyard time...
    You can get a complete HEI around here from a junkyard for 25-30 bucks,cap,coil,wires and all!...its getting harder to find the older ones with vacuum advance though..since the "crushathon" began earlier this year when scrap prices shot up over 100 bucks a ton,nearly everything older than 1985 or so is long gone..:( ....might not be the case in your area though..:crazy:
