can anyone educate me on waterpumps
Discussion in 'The Garage' started by m j, Nov 21, 2004.
  1. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    Time to replace the pump.
    any reason to look at aluminum?
    any year or model have advantages?
    I am not sure what I have on there now but I know the clutch fans I have on hand (1981) did not match the mounting pattern but I cannot recall why it didnt bolt up.
    any help or swapping secrets appreciated
    thanks
  2. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    stock always worked fine
    for me
    if you want to upgrade
    maybe swap a ford motor in /forums/images/graemlins/wink.gif
  3. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    You might check out the marine water pumps. They're supposed to be built a lot better. I'm sure they come with a price though. /forums/images/graemlins/thinking.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A water pump is a water pump...just get a new one.
    Aluminum doesn't rust. /forums/images/graemlins/rotfl.gif
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    anyone ever just rebuild one?
    isnt it just a bearing and a few seals?
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    if I go bigblock it is getting a Ford
    I wanna see what it takes to split the sbc with the turbo first
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I would get a new one.
  8. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    some water pumps you can. you just buy the internals and replace it. thats how they remanufacture them i think. unless they do it a different way.
  9. mr_beer
    mr_beer 1/2 ton status
    Sep 10, 2004
    325
    Mt. hermon LA
    Yea pumps are cheap, I'd get a new one too so you wouldn't have to worry about over heating. Engines aren't cheap /forums/images/graemlins/yikes.gif
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    "new" vs rebuilt or just grab a rebuilt?
    I like the cast one as everything (except my van ps pump) seems to mount to the water pump on my SBC, cheap too
    thanks guys
  11. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Marine pumps have bronze impellers & a stainless steel back plate, I believe they also have ceramic bearings, they are also bi-directional... so, no, a water pump is not a water pump. I have seen them on ebay for pretty cheap, and they're usually for SBC.
    Don't know if mj is looking for better performance, or just built to last? /forums/images/graemlins/dunno.gif
  12. dyeager535
    26,975
    Only people I know of that have gone through this, are Olds folks, although it is at least a GM product.
    They found that the impeller can be different (overall size, fin count) based on vehicle or options, and that the GMB aluminum pumps seemed to be designed to move more water, efficiently, than the stock stuff.
    An anti cavitation plate is part of GMB's setup as well, from what I could tell.
    I don't see how moving more water when needed, can do anything but help.
    www.corvettefever.com might have their water pump rebuild article online. For a stock non-collector setup, I'd just buy a new one though as opposed to rebuilding. Weren't worth the time/parts compared to a $25 or so rebuilt one.
  13. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I know some Ford racers cut the water pump impeller down quite a ways to reduce engine drag.
    I havent had a over heating problem yet but there is some strange sounds coming from the front of the sbc
    do not recall the age of the water pump so it is getting changed when I do the rad.
    what years had studs instead of bolts to retain the pulley/fan?
  14. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    If I were to buy a waterpump for a SBC today I'd buy an aluminum pump. Price for aluminum versus the factor reman stuff isn't out of line. I'd also buy an impeller backing plate at the same time and who knows maybe you can find an aluminum pump that already has an impeller plate on it. I'd also think the aluminum might scavenge a few degrees for you as well.
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    All of mine have had studs.
  16. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    so parts whiz, what year did that change over
    I think it was the studs and the differing size of the shaft that prevented me from using a newer clutchfan.
    what year pump do I need to order
    more 'easy, chevy, everything swaps' but it aint so
  17. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    19.99 for a reman pump. Stock pump should cool more than you need. Enough said.
